Question about NetGear FVL328 and FA311 (fvl328/fa311-kit) Firewall
Port Forwarding How do i handle port forwarding on this router?
    Novelist:
    Scholar:
  • 123 Answers
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Posted on Feb 19, 2006
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
I have port forward for my vuze program but evertime i hook the internet up i can still go on line like with ie but if i do ping test i loose packets and speeds are down to nothing, what i need to know if...
First off if you download the new version of Vuze, and your Linksys is somewhat new, it will have pnp feature. The new Vuze will automatically configure the router for you. Just in case your port forwarding only allows a few ports or your somehow blocking port 80. You didn't mention the model of Linksys, but if the router has port forwarding capabilities then it new enough to handle the amount of connections-(MAYBE) That would all depend on how many connections you've chosen on vuze's to allow per download. I would go with Vuze's defaults. I haven't had much problems with that. Even thou it's nice to download a large movie or program in 5 minutes, it's will slow down all of your IE connections. I usually download in the middle of the night, when I go to bed, I setup what I want and by morning it's done. That way your interfering with IE speeds.
Mark
Jun 09, 2010 | Linksys Computers & Internet
Port forwarding of Router D-Link DI-634M
Yes this router has a port forwarding capability, to know about that and how it is done from this router check this link.
http://portforward.com/english/routers/port_forwarding/Dlink/DI-634M/DI-634Mindex.htm
Feb 23, 2010 | D-Link DI-634M Wireless Router (DI634M)
Netgear rp614 wont port forward
my hp previon labtop (vista) does not detect the sognal from the netgear router . How can i solve problem
Jul 16, 2009 | NetGear RP614 Router
Router cant handle two pc's connecting to same server
Try to do port forwarding. Search for the port number that the game uses and open it on the router's Setup Page using Port Forwarding.
Apr 25, 2009 | Linksys (WRT54GC) Router
New topic about Intellinet Active...
You have a switch which is like a hub. You want a router, the router will assign IP addresses to each computer in your home. If you need to set up port forwarding then you do that within the router settings. For the most part newer routers have Universal plug and play which will handle the port forwarding for you.
May 31, 2008 | Intellinet Active Networking Intellinet...
How is Port Forwarding Configured?
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear (RP114NA) Router
Port Forwarding
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
NetGear FVL328 and FA311 (fvl328/fa311-kit) Firewall Logo
140 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
