I need to make a System restore on the computer as it won't work
    New Friend:
  • 68 Answers
To run System Restore, you must be able to log on to windows. After that, start System Restore as shown... I need to make a - e186e1a.gif
Posted on Sep 08, 2008
    President:
  • 2,961 Answers
Power on the pc, but as its booting press F8, you will get a menu, highlight 'last known good configuration, and press enter for a restart.
If that doesn't do anything press F8 again while booting up then choose safe mode instead, then a lot of writing will roll down the screen, warn you that you are in safe mode, click ok.
When you are presented with the log in accounts, choose administartor, then click start>programmes>acccesories>system tools>system restore, then choose a restore date that is not greyed out before the problem started, then allow a reboot.
    Problem Solver:
  • 19 Answers
Try to create another profile with admin rights, and login to this profile then try to run the restore. ior you can try to repair your os using the CD. :>
Satellite L655 won't fire up, orange Indicator on front edge flashes
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 21, 2013 | Computers & Internet
Need to restore my Phillips iqor computer to factory settings but do not have a disk
You need to boot your computer then look and see if there is a Recovery Partition on the hard drive. Click Start/My Computer and see if there is a Recovery Partition listed. Some times the partition might be hidden so check your owners manual and see what it says about recovery.
Have you tried doing a system restore to a restore point (date and time) before you started having problems? It's much better than System Recovery because you won't loose any data. Click Start/Program/Accessories/System Tools/System Restore.
Apr 30, 2012 | Computers & Internet
After Installing Windows Xp from Sata Cdrom everything works fine but when i Removed The Cdrom The Windows Won`t Boot Please Any solutions I diabled Sata from Bios All the same Eveythibg works fine when i...
did you remove all power and sata connections restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Apr 09, 2012 | MSI Computers & Internet
I have a 320 gb hdd i don't know if it works properly or if it is fine but my laptop won't load up
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
hope this helps you
Feb 17, 2012 | Samsung Computers & Internet
Restore
How to Restore an HP System Without a Disc
The HP computer uses a Microsoft Windows operating system to allow multiple users on your system. When your computer isn't working properly, you can do a system restore to restore the computer back to an earlier version. When you restore your HP computer, you will get rid of any viruses or malware that are on your system. You won't have to get in touch with Microsoft or HP to perform this restore, and you don't need any kind of disc.Windows contains all of the restore applications you need for your HP computer.
Instructions
1 Turn the computer off and then turn it back on. Hold down the "F8" key when the computer starts to enter Windows Boot mode.
2 Key over to the "Safe Mode With Command Prompt" option with the arrow keys on your keyboard.
3 Log into your system as an administrator. Enter the administrator password into the field when prompted and then click on the "OK" button to log in.
4 Type "%systemroot%\system32\restore\rstrui.exe" and press the "Enter" key to begin the computer's restore process.
5 Go through the system restore prompts to restore your HP computer.
Restoring an HP computer to factory settings requires that you do a system recovery. There are two types of recovery for HP computers: destructive and non-destructive .
Dec 05, 2011 | HP Compaq Presario SR1820NX (ER919AA) PC...
My computer won't do a system restore. Why not?
Unless a RESTORE point was SET up when the last installation was done , the system cannot be set to a restore state of an earlier date.
So you will need to reinstall or try with a recovery disc.
Jul 26, 2011 | Sony VAIO® VGN-N160G/W PC Notebook
My computer has no sound device detected
The computer could be having some problems with its driver which is responsible for making the system to communicate with its sound card. There are two ways that you can do to make it work. You can do a system restore (restoring the computer to known good date) and by downloading the updated sound driver which you can get from the website of your computer's manufacturer.
System Restore
1. Click on start or the pearl button>programs>accessories>system tools>system restore
2. A window will open up. Select the date when your computer was still working fine.
3. Follow the instructions that will appear on the screen and let it finish until it will tell you that the restoration is complete.
Note: System restore won't affect the files and documents that you have saved in your computer. But, it will remove the programs and updates which happened after the restoration date that you will be selecting. Updates and changes in the computer's programs sometimes are the reasons for some corruptions in the system.
Driver Update or Installation
Go to the website of your computer's manufacturer. Then, look for support and downloads. Select drivers or drivers and downloads. Put in the model of your computer and look for the sound driver. Install it.
If you still have some problems right after doing the above mentioned steps, then message me. Just post your message here.
Thank you for using fixya.com.
May 15, 2011 | Computers & Internet
How to manually reset computer asus Eeepc 2g surf
You want to restore to factory condition this is called formatting which you will need the software disc...All you could restore your system back to a earlier date which you will find under control panel information and your looking for information like system restore...Need more help please contact me Cheers nikki
Please rate my answer. Thanks for using FixYa.
Jan 15, 2011 | ASUS Computers & Internet
Windows freezes up before boot is complete
If you have your computer Recovery disk, place the disk in the drive and restart the computer. It sounds like your OS is corrupted and needs to be reloaded.
Apr 05, 2010 | EliteGroup P6IWP-Fe Motherboard
I want to restore my last week set up? how to do?
Using Windows Vista System Restore Windows Vista has a feature called System Restore that automatically backs up registry and system files whenever you install new software or drivers. This feature is useful when you install evil software that makes your computer run really slow. But don’t worry, System Restore won’t remove Windows Vista.
Using System Restore in Windows
There are two places that you can use the system restore feature from. From within Windows, you can just type restore into the Start menu search box, and you’ll immediately see System Restore at the top of the start menu:
95afb90.png Or you can type rstrui into the search box and hit enter. Your choice.
You will immediate see a screen where you can choose to roll back the system to the last restore point. You can select “Recommended restore”, and just click next, or you can choose a different restore point
23c0f17.png If you do choose a different restore point, you will see a list of restore points that you can choose from. How many times have I typed the word choose at this point?
You’ll notice in the screenshot below that the last thing I did was install Virtual CloneDrive to mount ISO images, but right before that I installed the NVIDIA drivers.
323d69a.png Click one of them, and you will have to confirm and then restart your computer to roll the system back.
6022678.png If you receive an error while restoring, then use it from safe mode and it should work fine. To get into Safe mode, you can reboot and use the F8 key right before Windows starts up.
If Your System Won’t Boot
If you can’t even get into windows, you can boot off the installation dvd, and choose the “Repair your computer” option on the lower left hand side. .
Click next on the next screen, and then choose System Restore from the System Recovery dialog. It will take a few seconds to come up, and you will see the same screen that you would see in Windows:
da0479a.png Click next, and on the next screen select the drive that your copy of Windows Vista is installed on.
Click Finish, and Vista will roll back to the previous restore point.
Aug 11, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
