Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
Joystick does not select down
Hi, I was unable to select the down option using the joystick on my Sony Handycam.
I opened it up as I thought it would just be a case of adjusting the rubber (as on a keyboard key)
Boy was I wrong.
Would you be able to send me instructions on how to put my Handycam back together again please.
  • 2Luvlee Sep 08, 2008
    Thanks for your help,
    Where do I find this?
  • 10,594 Answers
You need below mention service manual to fix your DCR-TRV19 camera.
Regards,
Joystick does not select down - 6b0a2b7.jpg .......
Posted on Sep 08, 2008
  • Shahid Electronics
    Shahid Electronics Sep 08, 2008
    please email .. "welcomejee AT yahoo dot com"
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
My sony erricson k750i phone's joystick is not responding
you have to clean the joystick by using contact cleaner. open the cover of joy stick, there is a switch inside it having a metallic cover. use contact cleaner and let it for few minutes.
DONT FORGET TO REMOVE LCD FIRST. it can be damage with contact cleaner. i had a bad experience of it.
btw it happens with sony ericsson phone joystick problem.if joystick problem still persist u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.
thankyou.
May 06, 2009 | Sony Ericsson K510i Cellular Phone
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
Nov 11, 2008 | Sony Ericsson Z525a Cellular Phone
Setup wizard
First open your phone, then press upper right (-) key to get to menu. press joystick down 2 times, then right 1 time, to get to Settings. Press joystick center select button, press joystick down 9 times to get to Master Reset, press center select button. Joystick down 1 time to get Reset Device, press center select, then press upper left (-) key. This will delete all user settings & data, including pictures, messages, data, sounds, games, contacts etc. The phone will be restarted. If this doesn't fix the problem, you will most likely need to replace the internal wiring harness.(Not a job even I would enjoy!) Hope this helps.
Oct 31, 2008 | Sony Ericsson Z525a Cellular Phone
Problems with Sony Ericsson Z525a Cellular Phone
First open your phone and be sure it is on. Next select Menu. Press the joystick right 1 time then down 2 times to get to "Settings". Press Select. Joystick up 1 time to get "Master Reset" & select. Joystick down 1 time to get "Reset Device" press select. Press "Yes" and the phone will be reset and restarted. Hope this helps. -Mike
Jul 14, 2008 | Sony Ericsson Z525a Cellular Phone
Sceen is blank and i need to turn off bluetooth
Start with the Z525 closed. Next open your phone. Press the right (-) key 1 time to get Menu. Click joystick down 2 times, then joystick right 1 time, & then center joystick select button 1 time to get Settings. Click joystick left 1 time, then center select button 2 times to toggle Bluetooth OFF. Close phone & you're done. I hope this helps. -Mike
Jul 10, 2008 | Sony Ericsson Z525a Cellular Phone
Mini DvD-RW problem
You've recorded your video and you're ready to view it on a PC.
Now you need to finalise the disk before you can see it on the PC, otherwise the PC will not be able to read it.
To finalise the disk, connect your camera to the power adapter, plug the adapter into a wall socket, and switch on the wall socket, then switch on the camera.
To get to the finalise step. switch on the camera, press FUNC (on the top left side of the camera), move the joystick down to get to MENU, press SET on the joystick, move the joystick down to get to DISC OPERATIONS, then select FINALIZE, using the SET on the joystick. Finalising will now start.
Make sure you do not move the camcorder or switch off the wall adapter during finalisation - this could cause problems.
Feb 23, 2008 | Canon DC210 DVD Camcorder
Joystick not working
Hi Stephen I also have a sony ericsson (D750i) with joystick problems. As i suspect it's dust clogging the contact points beneath, what i do to clear it is use a fine old toothbrush to brush around the opening of the joystick and it also helps if you blow hard into that area...i imagine a compressed airline would be ideal. Iknow it seems a bit primitive doing this to such a technologically advanced phone but it does work....even though it is only for a couple days. As i've got about 4-5 months left on my present 18 contract, my next step is to see if one of those mobile phone "hospital" shops can open it up and give it a good clean and maybe sort a new facsia for it. Anyway, i'm not sure i'll be going for a sony next time....unless they can sort this problem. Good Luck Andrew
Dec 20, 2006 | Sony Hands-Free Earset for Ericsson K750...
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
147 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
