Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Sharp AQUOS LC-60C52U
Hi
I have a green line down the side of my screen on digital channels. ????
Reid Whitsett
562 366-0366 X111
  • Anonymous Mar 21, 2014
    horizontal lines after a couple minutes
Hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Posted on Sep 29, 2008
Sharp aquos LC-52D85U transparent line down the right side of the screen
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs' and can make sure about the fault.
Apr 19, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My sharp aquos won't power on
CHANGE IC202 WITH TL431 OR TRY PUSH INPUT AND VOLUME DOWN THEN PLUG THE POWER UNTIL THE GREEN LIGHT START ,,, WHEN IT START PUSH VOL DOWN AND CHANNEL DOWN AT THE SAME TIME AND PLAY WITH THE SETTING
Apr 20, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp aquos LC-C3234U. It had the blinking green light problem. I followed the first couple of steps ((vol up, chl down) and it now comes on with a solid green light. I have sound, but no
Search on eBay for RUNTKA448WJQZ and buy one.
I mean for $35 delivered it isn't much of an investment.
Don't forget to rate me if it works (and forget me if it doesn't; but it will).
Oct 12, 2012 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
We have lost our digital channels on our sharp aquos. how can i get them back. ex. 5.1, 5.2, 17.1 etc
Remove the coax cable from the television
Unfortunately your digital tuner may have gone kaput. I hope not but try an init and then rescan the channels. Unplug the television. Press and hold down input and vol-. This might take two people. While holding those buttons down on the television NOT on the remote have another person plug the television in. Keep holding down on those buttons until there is a k (green) on the left side of the screen. Then release the buttons and hold down vol - and channel - until the service menu comes up on the screen and release the buttons. Scroll down once with your down arrow on your remote until you are on page 2/26 (might be 2/some other number besides 26). The press the right arrow to turn on INIT + cause on. Press enter. When the screen turns green unplug the television without powering it down or anything. When you plug it back in it will prompt you back through the setup process.
Replace the coaxial cable before completing the setup.
If you do not have this exact model number do not complete the steps above without consulting again with the correct model number because you can wipe the memory of the television if you do not complete the right choices to bring up the service menu.
Dec 04, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Apr 30, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
973 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
