Question about RIM BlackBerry Pearl 8100
My blackberry does not work it can't open ,no image I SEE NOTHING ON
    Sergeant:
  • 367 Answers
Without further details
I assume you either have it working or got another phone but... remove battery for a few seconds then check Sim card (if used) reinsert and replace battery then check phone.
Posted on Jan 19, 2009
Phone powers on to white screen then nothing..blackberry pearl 8100
plug it into your pc and then after that, open the app loader on your desktop manager. run through (add remove programs if you want but you dont have to) when you finish, the phone sghould be able to work.
Mar 07, 2010 | RIM BlackBerry Pearl 8100
Hi,I have a BB 9530.My phone fell,it's working,but the lower keys is not working,the touch is working when I press on the screen nothing works.When the screen saver comes on and the phone goes blank,and I...
Sounds like you have a digitizer. Somebody needs to open your blackberry to replace it. Go to your provider, they might replace the phone for you. If they refuse and If you want somebody else to do it for you can go to Blackberry Repair. If you want to do it yourself, here is a Blackberry 9530 Repair Guide that shows how.
Feb 27, 2010 | RIM BlackBerry Storm 9530 Smartphone
I am not able to view the pictures. when i click
I recommend you correct your phones behavior by replacing its firmware and system software. The latest BlackBerry Bold 9700 system software is available through here.
Jan 25, 2010 | RIM BlackBerry Bold 9700 Smartphone
Keypad unlocks slowly and misses incoming calls, keeps saying "device memory full," shows 0.0KB free space in the Application Memory while Device Memory has 798.1KB and Media Card has 967.1KB Free Space......
Make sure there is enough memory available on the BlackBerry smartphone, and iit s not less than 5mb.
To check the memory on the BlackBerry smartphone, complete the following steps:-
1. From the BlackBerry smartphone home screen, click Options > Status.
2. If the File Free field is less than 5mb items have to be removed to increase the available memory.
If in case the above resolution is not working you need follow this complete procedure:-
1. Connect the BlackBerry smartphone to the computer using a USB .
2. Open BlackBerry Desktop Manager.
3. Click BackUp and Restore > Advanced
5. On the right hand column click Content Store, and then click Clear.
workaround:-
save the media (mms, images, Audio) to your microSD memory card instead of images, using the internal memory on the BlackBerry smartphone.
Oct 23, 2009 | RIM BlackBerry Bold 9000 Smartphone
Instant Message wont open
reinstall the application with the help of BlackBerry Desktop Manager
Jul 03, 2009 | RIM BlackBerry Bold 9000 Smartphone
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My phone has an error that say device error 400 reset. it wont even let me use it or nothing
When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message:
Device error 400
OR
your BlackBerry device resets itself and stops responding.
CAUSE
An unspecified error has occurred with an application on your Blackberry smartphone.
RESOLUTION
NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
  1. Disconnect your Blackberry smartphone from your computer.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Jun 11, 2009 | RIM BlackBerry 7290
Bb messenger will not open on blackberry storm
heres what i would try.
go to the advanced option in your blackberry device manager, open the .ipd file he has as a backup, then select the file within the .ipd labeled "service books" load only that software and allow it to reboot. then log into your bis email account on a computer and inside your blackberry bis email account there should be a tab call service books, select this to transfer your new service books to your phone and have them reinstall. after that you should be go. be sure to pull the battery afterwards and allow it to completley reboot. if this still does not work check your tcp settings against what your service provider says it should be! please let me know if this works because i have more solutions but it requires a crack to do it and youll need a step by step!
May 17, 2009 | Cingular Wireless AT&T RIM BLACKBERRY BES...
Blurry image on screen!!!!
you might to check that the phone has not been exposed to water fr a long time, also inspect if the camera lens is cracked or fogged up
May 02, 2008 | AT&T Blackberry Curve 8300 Smartphone
Can't get the HS850 to pair with my blackberry
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
RIM BlackBerry  Pearl  8100 Logo
22 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
