Question about Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66--can't change channels anymore
After 18 months of working fine, our plasma will not allow changing of channels. Regardless of whether one uses remote or side buttons, up/down channel button, or simply hitting any number on the remote's pad, feedback message reads: SEARCHING PLEASE WAIT. If one touches a single number on the remote, that number will appear on the screen as though indicating impending change, but then does not leave the channel it's stuck on (happens to be 24-1). I tried re-programming the channels in the menu, but still get the SEARCHING PLEASE WAIT message. I saw one other online posting describing the same symptoms. Can you isolate what chip/board needs replacement? I'm assuming it has to do with the tuner. But what do I know? (Wish I had the extended warranty.)
  • farm280 Oct 02, 2008
    I have exactly the same problem with 50hp66 after 20 month of use. Not only the TV can't switch channels, It can't switch inputs either. If I change inputs to watch DVD, I got the same "searching please wait" msg. Basically my toshiba 50HP66 is dead after 20 month.
I had this problem. Unplug it while it is powered on. Worked for me.
Posted on Nov 03, 2008
Toshiba Regza 32AV615DB
There is a input selection switching IC at the input section circuit. It t damaged. Seek experienced service tech: assistance.
Jul 02, 2012 | Toshiba 50HP66 50 in. Plasma Television
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Have you tried to unplug set for a while and turn back on?
If that does not help contact Toshiba to see if common problem on this model and if any possible software upgrade is available for this problem.
If still no luck someone will have to examine it and decide which board is causing this and replace it.
Mar 22, 2012 | Toshiba 50HP66 50 in. Plasma Television
TOSHIBA 50" MOD.#50HP66 appears vertical
A part of the buffer memory from the image processor is faulty and all the data stored in there is corrupted, hence the lines you see.
What you must replace is the board on which the processor is situated, the logic one. Here it is
http://www.partstore.com/Part/Toshiba/Toshiba/50HP66/Toshiba/Toshiba/75003034/New.aspx
Feb 26, 2011 | Televison & Video
Problem with tuner
Found the solution somewhere else...
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Toshiba 50HP66 plasma
It can be the power supply, and or a short on one of the boards that is causing the set to go in to protect mode.
The service tech will swap out boards to find the problem. He will leave the board installed that does the fix.
Be prepaired, these sets are rather expensive to service.
Jerry G.
Apr 21, 2008 | Toshiba 50HP66 50 in. Plasma Television
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 50 in. Plasma Television Logo
403 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
