Question about Amana ABD2233DES Bottom Freezer Refrigerator
Amana Bottom Freezer
I want to dust and clean out underneith my frig. Does this type have tray or do I have to unscrew back and vacum?
Thanks
Renee
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: NO ICE IN MY BOTTOMFREEZER AMANA REFRIGERATOR
If we both are on the correct subject then it is possible the water control valve on back of refrigerator is not working. If ice tray is dry then fill with water from a cup and let freeze. If the ice maker dumps the ice let me know and we will go from there. Sea Breeze
Posted on Apr 26, 2009
freetek
  • 5568 Answers
SOURCE: Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Posted on Feb 25, 2010
SOURCE: My fridg and freezer isn't cooling or freezing
phil is the fan that cools the coils running
Posted on Apr 13, 2010
heatman101
  • 43501 Answers
SOURCE: amana frig model#scd25tw freezer and frig not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 28, 2010
I have an Amana Regrigerator/bottom freezer (ABB2224DEB). The freezer and refrigerator are not cooling. Have already cleaned dust out from underneith.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 31, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
There is lots of dust under the refrigerator but I can't reach it to clean it. Does the bottom tray pull out to get at it?
The bottom tray on most units will pull out.
However I have found that there are some better ways to getthe dust and dirt out from under there.
A good shop vac with a crevice tool is a great way to get in there.
Another way that I have often cleaned under neath is to use an air compressor with an air nozzle at high pressure. You can blow everything clean and then vacum up the dirt.
It is very important to keep things clean so that your compressor stays cool and the coils have good air for heat transfer.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Amana ARSE66MB Side by Side Refrigerator
Apr 26, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABD2233DES Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
