I am trying to setup my laptop for internet access
  • cobras Sep 09, 2008
    You could not resolve my problem for me!!!
  • andrew pester
    andrew pester May 11, 2010
    wireless or wired, modem or router, or dial up?
    President:
  • 2,961 Answers
Not without you answering the request, need more details
Posted on Sep 09, 2008
Belkin n50 setup as wireless access point
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 03, 2013 | Belkin Computers & Internet
Unidentfied network is connected, no internet access, i see a chair between the internet acces and the laptop. tried to reboot everything several times, turned off firewalls, nothing helps/
That unidentified network, have you connected to that before and browsed the internet? Just because you connect to a network, doesn't mean that network is setup to allow internet access. It could be a simple fact that you need to connect to a different network.
Jun 30, 2011 | Computers & Internet
Tried to install norton internet security now unable to access the internet
To Start, go to the “Control Panel,” you want to open the “Internet Options” window.
To setup the Internet Connection: Click on the “Connections” block, click the “Setup” button, follow all the instruction carefully. Important “Always click apply, ok, and restart the computer after making changes to the computer.” “Did this solution help? If so “helpful Rating Feedback appreciated, thanks paul7of9.”
Feb 10, 2010 | Computers & Internet
Cannot access the internet
I have looked at and reviewed your problem with your HP laptop DV6700Z and have the fallowing for you to aces.
First, if you are trying to access the internet via wireless, wait until you have established and wired connection.
If the blue light comes on in the front panel, the wireless is working, if not, you have a problem with the wireless modem.
Run a wire from your laptop to your modem and enter your my network, choose setup a internet connection.
Try to make a internet connection. Once you have established a connection, you can setup your wireless connection.
Hope this has helped you.
Sep 28, 2009 | HP Pavilion DV6700Z Notebook
I am trying to go wireless with my new laptop
Have you set your router up? That would be the first step to accessing internet wirelessly, as well as having Internet signals to the router.
Router setup can be sort of confusing, but the manual is pretty good for basic setup.
Sep 15, 2009 | NetGear DG834G Router
Wireless Connection
The WPA code is the password to access the router's network, so it can use your internet connection. As long as the Xbox has both the SSID and the WPA password, it can access the internet through the router.
The SSID ( Chris_PC_Network ) is mostly irrelevant to the network connection, and is purely aesthetical. Its only use is to help users distinguish between different networks (so you don't use a neighbor's network or vice versa).
May 24, 2009 | HP Pavilion dv6000z Notebook
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
Getting limited access on my laptop
Try to re-configure your router for the wireless connection and disable WI-FI protected setup located at advanced.
Feb 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
Internet problem
Rerun the network setup wizard on your computer. Make sure all computers, printers, and routers you want to use in the network are turned on and that an internet connection is present. Once you do this your problem should be fixed. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
