Question about Kodak Digital Science 2500D Path-Through Scanner
Line on far right of scanned documents
I have a Kodak digital science 2500D and when I scan a document there is a line down the entire page. I've used canned air and looked around for a peice of paper stuck but the line remains.
Most likely the scanner has dirt on the glass that is over the imaging array or the glass may be scrached. If the glass is scratch, the imaging CCD array need to be replaced. If you do not scan the rear of your documents, you can swap the upper with the lower in the case that one is scratched.
The imaging array are the green long bars, one at the bottom of the paper path halfway inside the scanner and the other is above it. Look closely for a small spot of black toner or dirt stuck
on the glass. Take a soft cloth, wet it with water or alcohol if needed and clean the glass.
Pass you finger over the glass, try to feel if all of the toner or rubber residue has been removed.
You might try looking at the specific area were your documents image is getting the line. It will
help you pinpoint where you should clean. CAREFULL not to push on the glass as this
might break it. Hope this helps.
Otaron
Posted on Nov 03, 2008
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Got a dark line down document when scanner via AFD
When you use the adf, the scanner remains stationary at the far left side of the platen. Check and make sure that the glass is very clean there; use a damp cloth to remove any dirt or other foreign material.
May 27, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Blue line down the right side documents
your not getting the cover closed all the way use the scanning software to make the scan go to the border of the paper onlt and then do a view print to be sure it is the correct size.
Nov 13, 2009 | ScanSoft PaperPort Deluxe 9...
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Line down the scanned document on a HP LAser Jet 3050
If you are scanning using the Auto Document Feeder be sure to clean the glass where the documents get scanned. A small speck will cause a line down the page. On HP there is often a narrow strip of glass on the left side of the platen glass.
Apr 10, 2009 | Brother IntelliFAX 4100 Laser Fax
KOdak 2500 D -- cannot find target device
Go to Kodak's website and download the scan verification tool (the SVT), and see what it tells you. I use the 2500D with an Adaptec 2940 SCSI controller, and a 50-50 pin SCSI Cable.  I use the twain driver from Kodak's website and paperport 9 software.  This combination seems to work.
Jul 14, 2008 | Kodak Digital Science 2500D Path-Through...
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
Is kodak digital science 3520DP a sorting scanner
The Kodak 3500 scanner series is probably the best scanner ever made, but NO, it doesn't read anything! Think of it as a digital camera. It only takes pictures. All OCR, ICR, BAR Code, etc. has to be read by software. Your software looks at the images and pull any info that it has been designed to detect off of that image. Some older scanners had built in bar code and patch code reading, but more and more, the software now does it, usually in conjunction with a Kofax card in the PC.
May 26, 2008 | Kodak Digital Science 3520DP Path-Through...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Kodak Digital Science 2500D Path-Through Scanner Logo
236 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
