Question about GE DBSR453EBWW Electric Dryer
Starts, but won't stay running
I turn the start switch. The motor and drum turn. The heating element heats. I release the start switch and all stops. I have run it through the timer several different ways. It will not start at all between the different cycles. ( Like it is supposed to). The timer ticks away in the timed mode. I checked the dual fuses, fine. I reset them anyway.
So is it the timer or the start switch?
Thanks!
  • showcow Sep 28, 2008
    I have the same problem now, when this first started our dryer would run fine but no heat, I started by replacing the element, thermostat sensor on the blower housing, No heat and would no stay running, I replaced the motor,Start Switch, Belt, Idler assembly and front drum pads and greased the drum pinion since my dryer was soon to be new again, Our Dryer then would only run with start switch engaged and no heat from the element,But I did Note that with the door open the light will no work and when the door switch pushed in the light only comes on when the start switch on the panel is engaged, Now I found that my 30 amp breaker was bad and was only getting one leg of the 220, with that proably my original trouble for dryer not heating. Should I do what My wife is suggesting, out with the Old and in with a New?? :)
    So here it is in a Nut shell
    1.Won't stay Running when start is released
    2. Light only comes on when Start is Engaged and the door is open
  • Anonymous Oct 08, 2008
    Dryer will start ok, but will not run after the momentary switch is released. Circuit breaker ok. Voltages ok. Power wiring ok. Door switch and light ok. Yesterday it worked fine, but today it will not run.
    GE Model DBSR453EB Electric Dryer
    Problem Solver:
  • 25 Answers
Just check the start switch might be defective change a new one.
hope it may help
regards
Posted on Sep 08, 2008
Dryer heats but doesn't completely dry clothes.
See if you could turn the machine and remove the vent hose on the back.
Then, after you are sure it is clear, try a load of clothes with the vent hose blowing out into the air, not hooked to a vent hose pipe through the wall.
Very often, a plugged pipe will cause this behaviour. The pipe could be plugged in the wall or somewhere else.
Be blessed.
Feb 18, 2013 | Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
Dryer starts but will not stay running
This is what is probably going on. There are two parts in the motor that cause the drum to rotate.
One of them is "start" winding. It literally starts the drum's rotation. Once the drum motor has started the drum to move. The second portion of the motor, known as the "run" winding takes over and keeps the drum turning. When the Drum winding burns out. The same symptom is caused when the switch attached to the motor is also damaged. In your case, although this is rare. I think it may be the switch.
The reason being is that the motor has a combination switch that also connects one side to the heating element. In a nutshell, If you get the dryer not continuing to turn AND the heating element stays on. There is a problem with the switch.
If you get the heating element going on when you push the start button but turns off when you release the button. The problem is the motor having a burned out run winding. Either way, it is less labor intensive to replace the motor when you take it out. Doing it switch is not easy. Hope this helps. If not write back to me and we can continue.
HAVE A HAPPY NEW YEAR
Best, Mark
Jan 01, 2011 | Kenmore Dryers
Dryer won't stay going after button is released and the door safety button is still functioning, also the heating element is still working.
Best, Mark
Dec 28, 2010 | GE Dryers
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer starts but wont stay on
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Jun 14, 2009 | Kenmore Dryers
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryer housing gets hot when the dryer is plugged in
if the dryer is gas then a 110 ac volt plug is sufficient. If it is an electric dryer than it would be 220 ac volt wich is a four prong plug, a common with a L1 L2 and ground. If it is in the USA (im in canada) they may if memory serves use common for ground. what ever the drier plug was when first manufactured is what you want to use. It sounds like there is a short to ground (common/nuetral) from the element. when the timer is in the on possition power from one side of the circuit is present. when you start the drier with the start switch it provides contact to the other side of the circuit. check the element and that should be your problem.
Sep 25, 2007 | Dryers
GE DBSR453EBWW Electric Dryer Logo
127 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
