Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
How can i erase all infomation and reformat this external drive
  • 689 Answers
Hi
Right click on the related drive letter under "My Computer" choose "Format" and proceed. That will start several minutes progress depending on the access speed. After format complete it will be totally erased.
Good Luck
Posted on Sep 08, 2008
  • ExpressFiX
    ExpressFiX Sep 08, 2008
    If you are using different Operating system please indicate so we can provide info accordingly
How do i reformat my external hd
if your using windows just right click on the drive and select format. in mac go to disk utility and select drive. choose erase and erase drive using either fat32 if you want read/write support for windows or just format as mac journal
Feb 23, 2012 | Western Digital My Book Essential 1TB...
How i can reformat toshiba canvio 320 g on my macbook pro
To totally reformat the hard drive which will delete everything off it. Go to your applications folder and then to the utilities folder and double-click on disk utility. In the left hand column select your drive then select the erase button once on the erase section select the format you want to format the drive in (if you are only going to use it on a mac select Mac OS Extended, if it is going to be used on both macs and PCs select MS-DOS (FAT)) then choose the name you want to call your drive and then select erase.
REMEMBER THIS WILL WIPE ALL THE FILES ON YOUR HARD DRIVE.
Hope this helps.
Sep 15, 2011 | Toshiba Canvio Plus 320 GB 2.0 Portable...
How do I format my external hard drive with my macbook
Disclaimer: the following process will reformat your external drive, and also erase all the data on it. There is no possible way to reformat the drive while retaining the data, as reformatting requires erasing.
Press cmd+space to open up spotlight (or just click the magnifying glass in the upper right corner) Type "disk utility" and the first result should be an app called "Disk Utility" and has the icon of a hard drive with a stethoscope. Hit enter.
Connect the hard drive to your computer, and you should see it pop up in the box on the left side of the window. You should actually see two things: a disk icon with the size of the drive and maybe the brand and, below it and slightly indented, a disk icon with the hard drive's name next to it. That's the one you want to click on. In the top middle of the window, you should see an "Erase" tab. Click on it. Pick "Mac OS Extended"* in the Format drop down Rename it if you want to in the Name text box
Click the "Erase" button
It will then reformat the drive to be compatible with Macs.
*Use Mac OS Extended if you plan on using it to store files. If you want to install Mac OS X on it, choose "Mac OS Extended (Journaled)". If you want to be able to access the files from a PC running Windows, you should choose "MS_DOS (FAT)", though I would not recommend doing that if you don't have to, because it is rather slow.
Sep 12, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
How do I reformat my toshiba canvio 500gb external hard drive for my macbook? If I go to disk utility and erase it, wont it erase the backup software as well?
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Dec 25, 2010 | Toshiba Canvio 500 GB USB 20 Portable...
Can you tell me how to reformat my WD Elements external drive for use with a Mac? Thank you
You can use a pc formatted drive with a mac but to format it as a mac drive go to applications then into utilities then go disk utility. Once opened in the left hand side choose your hard drive on the right hand side you will see buttons "First Aid", "Erase", "RAID and "Restore". Click on Erase under volume format choose Mac OS Extended (Journaled) then name your hard drive and then click the erase button down below the name box. Hope this helps
Jul 06, 2010 | Western Digital Elements powered by WD 320...
Reformatted the external hard drive and lost files
Unfortunately, there's no way to retrieve any PC files. Once you reformat your external HD, everything would be erased.
Thank you!
Jan 04, 2010 | Computers & Internet
Erase and reformat to be compatible with new mac
Think I might have solved it myself. Here's how:
Open Disk Utilities and select the external hard drive. Select the "Erase" tab. Hit "Erase" at the bottom right.
That's all. Just dragged a folder onto it and it worked.
May 08, 2008 | Maxtor OneTouch II external hard drive...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
99 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
