Question about Canon imageRUNNER C3220 Color Copier
Error code E000003-0001
I am getting an error every time this copier turns on. The screen tells me that I need to turn off the copier completely and then turn it back on. I have done this numerous times and had no result. After about 30 seconds, the screen turns off and will not accept any input. None of the buttons are doing anything either. At this time I do not have the luxury of getting a technician out to my facility. Any ideas would be great.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Unfortunately you need a tech, unless you are a handyman.
there is a problem with the fuser,
either the thermistor ( heat regulator)
the thermofuse ( fuse)
or the heat lamp has gone bad
Posted on Sep 09, 2008
I got an Error code (E000001-0101) for the Canon iRC4580 series. how do i fix it? need urgent answer
  1. you have to access service mode by pressing these buttons in order.
  2. additional functions
  3. 2 & 8 at the same time
  4. additional functions again (press reset and try again if screen doesn't change)
  5. screen changes to service mode
  6. press copier/function/clear/error then ok in the lower right corner
  7. turn machine off and on. If the fuser assembly is still good it will reset, if not it will need to be replaced (by a tech)
  8. DO NOT ATTEMPT TO DO ANYTHING ELSE IN SERVICE MODE!!! YOU CAN COMPLETELY DISABLE YOUR MACHINE!!!
Feb 18, 2015 | Canon Office Equipment & Supplies
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
Error code 4021
4021 indicates Print job power failure
When there are running jobs, perform the job in error again after the completion of the running jobs.If the error still occurs, turn the power OFF and then back ON, and perform the job again.
Jun 23, 2012 | Toshiba E-Studio 456 Copier
Error msg E000001-0000 What can we do
that is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
Aug 16, 2010 | Canon imageRUNNER 5000 Copier
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
Oct 08, 2009 | Canon Office Equipment & Supplies
Canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Apr 17, 2008 | Canon imageRUNNER 5570 Copier
Error 001Fuser Problem
*then
2+8then
this will get you into service mode choose COPIER
then FUNCTION then
CLEAR then
ERR or ERROR then press OK(bottom right hand corner of screen)
turn power off then on
Thank you
Mar 12, 2008 | Canon ImageRUNNER 330s Copier
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Error code no. E00004-0000
the fuser has a bad
thermistor or
thermofuse or
lamp
Dec 20, 2007 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER C3220 Color Copier Logo
2,742 people viewed this question
old marine
old marine
