Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Same problem, green falshing light
How do you get to the boards? Is there a diagram somewhere? I started to open mine up and it looks like I have to remove the whole screen assembly to get to the boards. Can that possibly be right?
Thanks,
Dale
  • Mitsubishi Master
  • 8,617 Answers
No the boards are located inside the metal chassis block which is located on the left side looking in from the rear. You can get the service manual at the following link which will help you get the chassis out and help you identify the circuit board locations. Its under the mitsubishi category.
http://servicemanuals.vstore.ca/
Posted on Sep 11, 2008
15 sec intervel beeping coming from PC tower, #1 green light occaisionally lights up on key board, screen not opening up
There's a high probability that it is caused by a loose cable. Certain graphics cards require extra power, so there's a power cable connected to it. If that cable is disconnected and the computer started, the card makes a loud beeping noise to alert you to fix it. Consequently insufficiently powered graphics card is unable to display any image.
How to investigate this?
1. Open up the computer (assuming you have the skills and courage to do so)
2. Try to find the graphics card (it could look something like this: http://img.tomshardware.com/us/2007/05/08/system_builder_marathon/low_end_inside_02.jpg)
3. Look for the corner of the card. The cable should go somewhere here. Here's an example image: http://www.nvidia.co.uk/content/slizone/how-to/install_second_gpu/SLI_Install58.jpg
4. Look for a compatible cable somewhere inside the computer. BTW the cable might already be at the right place, but just not tight enough, so if it's already where it's supposed to, give it a little push to see if it goes just a bit deeper.
Oct 22, 2013 | Acer Computers & Internet
Renault Grand Scenic - Dashboard flashing red light, clicking noise throughout car.
Hey,
You can try another battery if you have one, or take the battery to be tested somewhere to see if its at fault
Thanks,
Ekse
Sep 04, 2008 | 2005 Renault Sportwagon
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
No picture, blinking green light
Mine seems to be a problem with the mainboard inside the monitor. take it apart and check the mainboard for any signs of problems. mine had some white stuff on the edge of a resistor. I cleaned and resoldiered everything i could think of (which is tough cause the components are crazy small) but nothing. I'm pretty sure mine is the mainboard since the large IC in the center of the board gets relatively hot when the DC cord is plugged in, regardless of whether anything else is plugged into the board itself, including the inverter, control panel, speakers, vga cable. I'm going to grab an LCD controller board from njytouch on ebay if they can get it to work with this LCD screen (they work but this one has a bit of a goofy lvds cable I'm currently checking to see if they carry). they're about 30 - 45 dollars with shipping and you can probubly jerry rig a method to mount it to the metal plate in the LCD housing to keep it looking somewhat presentable, but the side buttons are going to be useless and you'll need to mount an ugly button board somewhere.
Dec 31, 2010 | Sylvania CL572b (Black) 15 in.
TH-42PX70B wont switch on - standby light falshes green but TV won't switch on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Dec 02, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My Kenwood car stereo keep falshing the word "Protect" how to fix
in front of your #1 preset button there is a reset button push it with a pin. if you made a pass # put it in if not page 12 show you how to make one if you want. reseting it should make it work if it dont you have a short somewhere start from scratch buy taking it out. I suggest you dont make a password till the short is gone. Mine did the same thing but because i was pulling to much power on starting my car with my amps.
Jan 29, 2010 | Kenwood KDC-MP342U Car CD Player
2000 toyota celica green light on dash board
mine shows that when my lights are on at night
Jan 01, 2010 | 2000 Toyota Celica
Tv went black and no sound standby light falsh twice and paused and flashed twice again
This indicates a short happened somewhere in the set, causing the set to go into "safe mode" where it won't let itself turn on. Oftentimes it's the convergence board. Depending on what that will cost you, you may want to just replace the set.
Mar 01, 2008 | Sony KP-61HS10 61" Rear Projection...
What.....
I think I had the same problem as you... I found it was a power issue. I needed stronger batteries. Lithiums worked well.
Oct 23, 2007 | Olympus Camedia Stylus 300 Digital Camera
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
