GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Sep 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not Heating We have a GE Spacemaker Microwave Oven just past the one-year limited warrenty and it has stopped heating. It still runs, turns, everything, but no heat...any suggestions of what we could try? Thank you!
  • 4 more comments
  • kristic Sep 10, 2008
    Microwave was working fine with no problems until yesterday. We heated up some soup, mixed it up and went to put in back in for 30 seconds and all power went out on it. A little while later the power came back on, but now it doesn't heat when we turn it on. Any suggestions?
  • hunt485 Sep 10, 2008
    I have a GE Spacesaver JVM1653WH01 that wont keep running. You set the clock and strat to heat somthing and it quits in 3 to 15 seconds. After a few minites it is asking to set the clock again.
    Help ! ! ! ! !
  • Anonymous Sep 11, 2008
    Mine is 5 years old. After only 3 years the magnatron tube failed and it was no longer heating. GE replaced the magnatron tube and now 2 years later, the microwave stopped heating again. My GE refrigerator also failed after 5 years and my GE dishwasher is leaking. I can only urge you never to buy GE appliances again.
  • Anonymous Sep 30, 2008
    My GE Spacemaker is about 3 years old. It turns on, timer works, etc...but it does not heat. Any suggestions?
  • Sunny5554 Oct 02, 2008
    I have the same exact problem with the same microwave..how do we fix it?
  • jmshepherd Oct 02, 2008
    Yesterday my GE Spacemaker Microwave oven just stopped heating.  Everything else is working fine.  There is a strange noise that happens when I think the heating element should be heating:)  Anyway this thing is not quite a year old!
    I have taken your advise and called in a service request from GE.  Now I just hope I registered this oven:(.  I purchased it at Lowes and I called them they only keep track back 5 months.
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Sep 13, 2008
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4480815
Points
21747
It appears that all of your microwaves have bad magnetrons.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
But they send you a replacement magnetron. GE Customer Service is here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
My GE White Spacemaker Microwave just stopped heating-you hear the motor running but the light inside grows bright to dim by a few watts while going thru any cycle of heating. Any answers?
The magnetron has probably failed, there are also two other parts that can be a factor, the high voltage capacitor and diode, the high voltage is generated by these items which in turn heat the food.
My ge spacemaker microwave oven stopped heating. light still comes on and tray rotates but it does not heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Basic
heatman101
Microwave stopped heating, but i still hear the "motor" running. Also, the turntable stopped turning. How to fix?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fj
1helpful
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
heatman101
fgkjf
Microwave run with a different noise and stopped heating up food
heatman101
fkj
2answers
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
19helpful
2answers
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
4helpful
3answers
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
