Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Door handle loose
Looking at my ref, the right door handle is loose, how do i get to the screws?
  • donnaptowns Nov 30, 2008
    On a side-by-side refrigerator, the top of the right door handle is disengaged. How do we tighten it?
    Genius:
  • 1,122 Answers
If it is a side x side the covers side up to come off,some have little taps coving the screws that have to be popped out,mike
Posted on Sep 12, 2008
How does someone tighten the handle it is very loose
go to www.youtube.com
refrigerator door handles out loose
see if anyone has idea on how to fix it
most of the time is the way people word there questions or answers to get the right help
manufactures name, make or model #, handle are loose
how to fix
www.howto.com/manufactures_name/model#/service_manual
/ door_handle_diagrams
www.wikipedia.org/manuf./model#/doorhandlediagram
Mar 25, 2015 | Refrigerators
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
My door handle is loose side by side 2 years old
It is possible to tighten any fridge door handle but sometimes getting to the screws can be difficult. Begin by looking nder the door gasket right behind the handle and be prepared with a phillips head screw driver, the common size which is number two.
Oct 08, 2009 | Refrigerators
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator door handle is loose
If allen screws are there then that is what holds handle in place. There are screws that the handle fits over, so remove handle and tighten as needed. Allen screws are very tiny.
Nov 27, 2008 | LG Refrigerators
Jenn-Air Dishwasher Handle Loose
This worked perfectly for me. Follow the link that shows you which two screws to take out. It is one screw on each side of the inside door frame. One on the left and one on the right (not the top one, but the second one down). Then pull the door handle upward about 2 inches and the whole washer face comes up. Jiggle it off and tighten the handle. Only tricky thing is that you need a star screwdriver.
The problem I had in the beginning was that I took off the middle screws on top (cause that's what it looks like in the picture), but it's actually the side screws. Don't take them all off - just the two you need.
- Pokey
Oct 11, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
