Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Sudden blue shift
While watching, the blue video component on our PT-47WX53 suddenly jumped about 2 inches to the left, almost uniformly across the screen. Attempting on-screen correction, we found the image could not be shifted all the way back to the center. Adjusting as far right as possible results in distortion.
Given the other answers I've seen here, I'm guessing the solution will involve replacing ICs. If that's the case, I'd love to hear any thoughts on whether I should use the STK392-110 suggested by Slinteriors, or the C5AA00000203 suggested by Terryfic.
If anyone thinks the problem might be something other than ICs, I'd greatly appreciate any ideas you'd care to put forward.
Thanks for any help you offer!
  • Stephon McAfee
    Stephon McAfee Oct 01, 2008
    I have the same problem and would like to known what you guy are taking about.what is ICU
Use the 180's. I've just replaced mine and everything runs fine. I've heard they run cooler.
Posted on Sep 28, 2008
Red shift to left with curve at bottom
Par 2 = " I do see the convergence chips..."
Par 3 = " I'm not sure where the IC's are...."
Please verify STK part # of IC's on large heatsinks.....
And then I'll give you step-by-step instructions......T.
Nov 19, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen went black Panasonic TV/ PT-47WX53
Hello twisttolife,
What you have lost is horizontal deflection, this is caused by loss of the horizontal drive signal to the yoke transformers on the CRTs, for all three of these to fail at the same time is not likely so what I think is that the drive amplifier may have malfunctioned. To check this you will need:
1) schematic diagram or service manual (to determine the proper voltages and signals on the deflection board)
2) Multimeter (to measure the DC voltages on the components of the deflection board
3) Oscilloscope (to view the waveforms on the deflection board)
With these three pieces of test equipment you should be able to troubleshoot this problem.
Now if you do not have this equipment and what to take a chance at a blind guess, and just replace a board, I would suggest replacing the deflection board, this board usually contains the flyback transformer, the Convergence modules (which can cause this problem also), and the connections to the yoke transformers.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Oct 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
