I am having a Tappan 3.5 heat pump installed and the word "seer" keeps appearing. what does the term seer mean??
  • 691 Answers
It's a measure of a/c efficiency. The higher the number the better it cools and the less electricity you use. Window units are luck to get past 10. The government gives tax incentives for 13.5 & higher and the highest comes from mini split models(like Mitubichi) somewhere around 22-24.
Posted on May 18, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Type in the manufacture name till the webpage comes up and type in name and model #.
Posted on Sep 08, 2008
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Have tempstar model NFCX3600CZ Ser# L0239 58594 and unit will not switch from head mode to cool mode. Contractor says it's a bad reversing valve. cost will be $525 to fix. Question estimate.
I am a Technician myself and work for myself. Their price is fine if they don't try to add as they go. Reversing valves are delicate to install and you have the issue of recovery and disposal of the freon that was inside your unit. I am not siding with the Technicians either there are good ones and bad ones. Did this technician come out and test the unit or was this a quote on the phone? Depending on the age of your heat pump I would consider other factors. We also are nearing the end of the R-22 age and moving to better more efficient units that conserve energy. SEER rating means a lot if you add the cost of energy. The newer styles of heat pumps work under extreme pressure. The higher the seer number the lower the cost for energy. Your model may be a 10 seer I will look after I finish this post. Let me know the age of your heat pump. Remember a heat pump works all year round and not just summer months so life span is reduced. Thanks, Sea Breeze
May 16, 2010 | Ruud Central System Air Conditioner
Am having a Tappan Split system heat pump installed. Proposal was for a 14 SEER system including a FTBD042K heat pump and a BCS2M48C variable speed air handler. However Actual equipment installed is...
i dont think so that variable speed air handler is a nightmare when(not if) that motor goes bad its 700.00 to 900.00 the regular 3 speed one your getting 125.00 and it will last 10 to 15 years ....... if you realy want fun install a 17 seer system ,you will have your repair guy on speed dial
Mar 01, 2009 | Heating & Cooling
3ton heat pump googman 14 seer
Give me the model numbers on the heat pump and the coil, I would expect its a really poor match.
Nov 11, 2008 | Goodman GMS90703BXA Heater
What does the term "seer" mean in reference to your heat pump?
Seer=== Standard electrical effeciencency ratings .The rating to which the unit save on energy.
Sep 08, 2008 | Heating & Cooling
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
