What does the term "seer" mean in reference to your heat pump?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Seer=== Standard electrical effeciencency ratings .The rating to which the unit save on energy.
Posted on Sep 08, 2008
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Amana heat pump 13 seer split system when in heat pump mode once the thermostat is satisfied the head pressure on the high side shoots up to 600
410 a runs at a much higher pressure then r-22. that is still very high. it would take a temperture over 150 degrees to produce it on a idle system.
Feb 15, 2015 | Amana 3.5 ton 13 Seer Split Heat Pump...
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
What does it mean to
Reflow sounds like the article is referring to cracked solder joints, Reflow would mean to reheat the connection and top up means adding some more solder. In electronics, heavy heat sinks often crack where they are soldered because of expansion and contraction. RCA actually came out with a more flexible solder for this issue.
Oct 28, 2012 | Kenwood KDC-MP532U
What does the term "scratch" mean in reference to playing billiards?
When a player scratches, they pocket the cue ball. In the past players used to keep score on a chalkboard, so when a player pocketed the cue ball, his opponent would proceed to "scratch" a point off the shooters score.
Jul 25, 2012 | Sport & Outdoor - Others
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Have tempstar model NFCX3600CZ Ser# L0239 58594 and unit will not switch from head mode to cool mode. Contractor says it's a bad reversing valve. cost will be $525 to fix. Question estimate.
I am a Technician myself and work for myself. Their price is fine if they don't try to add as they go. Reversing valves are delicate to install and you have the issue of recovery and disposal of the freon that was inside your unit. I am not siding with the Technicians either there are good ones and bad ones. Did this technician come out and test the unit or was this a quote on the phone? Depending on the age of your heat pump I would consider other factors. We also are nearing the end of the R-22 age and moving to better more efficient units that conserve energy. SEER rating means a lot if you add the cost of energy. The newer styles of heat pumps work under extreme pressure. The higher the seer number the lower the cost for energy. Your model may be a 10 seer I will look after I finish this post. Let me know the age of your heat pump. Remember a heat pump works all year round and not just summer months so life span is reduced. Thanks, Sea Breeze
May 16, 2010 | Ruud Central System Air Conditioner
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
I am having a Tappan 3.5 heat pump installed and the word "seer" keeps appearing. what does the term seer mean??
Type in the manufacture name till the webpage comes up and type in name and model #.
Sep 08, 2008 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
