Question about Intel Motherboard
How do I get a computer out of power saver mode?
I was given an Imperial Deskpro CPU. There is no support for this brand. The Motherboard is a Intel Desktop Board D865PERL. It has a 2A pentium4 processor with 512mb of ram. It seems to power up fine except it will not bring the monitor out of power saver mode. I have tested the power supply ang replaced the graphics card with a known good GEforce4 MX440 8X 64mb DDR TV OUT card. still the same thing. I am no computer genius. Please help!
Thanx, Johnny P
  • JohnCoyote Sep 09, 2008
    I have heard there is a way to force boot a cpu into safe mode, Anyone that can enlighten me?
    Brigadier General:
  • 5,158 Answers
Keep tapping F8 as the computer boots up to boot to safe mode... well the option to boot to safe mode... other choses are there
Robert
As for power saver mode.... what operating system are you using ?
Posted on Sep 09, 2008
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
Where to find manual for motherboard 143159 imperial Gv 20030812?
Good luck. Used to be you could get a mobo manual from e4allupgraders.
The Imperial board is made by TriGem
Started out as TriGem Sambo, is now TG Sambo
The Imperial models were Imperial G, Imperial GL, Imperial GV, and Imperial GLVE, if memory serves.
TriGem Imperial GV - 143159 -20030812
http://www.ebay.com/itm/gateway-emachine-mother-board-imperial-gv-20030812-/111025938736?pt=Motherboards&hash=item19d9a96130
Bad photo, but it does have the mouse Zoom In feature.
CMOS jumper and Clear BIOS Password jumper, down by the Front Panel header; is the same as used on the TriGem Imperial GLVE -129504,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07540&lc=en&cc=us&product=83481
Scroll down to Motherboard Layout (Illustration), and Photo; then down to jumper info.
(By the way.........the BIOS chipset is removable, therefore replaceable)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
This is PANEL in the illustration. Bottom/Right corner. Uses the same Front Panel pinout, as your Imperial GV uses.
8 pins along in a row.
Starting on the LEFT side going towards the Right;
Pins 1, 2, 3, NO pin 4, 5, 6, 7, and 8.
A) Pin 1 is N/C. Not Connected
(May not even be there for all I know)
B) Pins 2 and 3 are for the Power On LED.
Pin 3 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
C) There is NO Pin 4. At least that is what I make, looking at the Front Panel header pinout. Indicate Pin 1 is N/C, and Pin 4 is N/C.
D) Pins 5 and 6 are for the HarDDrive activity LED light.
Pin 5 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
E) Pins 7 and 8 are for the Power On switch.
HOWEVER, since the motherboard photo on HP Support, and Ebay; is as clear as mud; suggest you do this,
Connect your Power On switch to Pins 7 and 8;
OR,
touch across them briefly with a small flat tip screwdriver.
(Power plugged in)
See if that is correct for the Power On switch. What will happen if it isn't? Nothing. Pressing the Power On button just won't turn the computer on; is all.
Turned the Power Supply (Computer) on?
Good. We can assume the rest of the pinout is correct also.
Want to make sure? Easy.
Take an LED bulb (Power On, or HDD), and touch it's two wires to the Power On LED pins, in the Front panel header.
Stays on? Yep. Power On LED pins.
Blinks? Whoops.
Those are the Harddrive activity LED pins.
Just that easy to check it. With using an LED, you won't harm anything even if the pinout is wrong.
Moving on.........
Using the HP Support page, for that TriGem Imperial GLVE motherboard, the Motherboard Layout is the same as the Imperial GV.
(So is photo, 'natch)
Referring to the layout, and photo;
A) Power cables:
Two
20-pin ATX main power cable, and 4-pin ATX +12 Volt power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note* Color of power cable connector does NOT matter.
Can be Whitish, Yellowish, Black, Sea Foam Blue, or Lactating Mammary Gland Pink. (Made the last two up)
Goes to the motherboard connector immediately above PCI slot 1.
Note the LOCK on the side of the power cable, and corresponding TAB on the motherboard connector.
General example of 4-pin ATX +12 Volt power cable, and connector on motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power for the Processor
Looking at the motherboard illustration, look at the Northbridge chip; -> Intel 845GL in the middle.
ATX 12V to the left, is where the 4-pin ATX +12 Volt power cable plugs in.
See the aluminum finned Heatsink, sitting on the Northbridge chip?
The whitish/yellowish 4-socket hole square connector, to the Left.
Moving on............
See where it states Primary IDE to the bottom/right in the illustration? Blue IDE connector?
That is where the Harddrive plugs in.
This is a general example of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Note the Locating Lug on the top/middle. This particular style uses two ribs. Some are just a solid block.
The reason I brought it up, is if there is NO Locating Lug on the connector; let me know in a Comment.
I'll tell you how to use the faint Red stripe, on the side of the flat cable; in order to plug it in correctly.
The optical drive (CD/DVD drive) plugs into Secondary IDE.
You can see where a Floppy Drive plugs in.
Above the Processor (CPU) socket to the Right, is where a computer case fan plugs in. PS_FAN.
To the upper Left, is where the Processor fan plugs in.
CPU_FAN
To the left of the ATX Power Connector, (20-pin ATX main power cable; motherboard connector), is the connector for the small audio cable; coming from the optical drive. (CD/DVD drive)
Optical Drive In.
Right next to the round CMOS battery, is the Front Panel USB header.
-> TWO USB ports connect to this header.
(USB)
A 4-pin Peripheral power cable is used for the Harddrive, and Optical Drive.
Misnomered as 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the rounded corners. When plugging the power cable in, these rounded corners always go UP.
[Molex was the first maker of the power cable connector.
The name stuck.
Kind of like calling an adjustable open-end wrench a 'Crescent wrench' ]
The motherboard chipset is an Intel 845GV.
This is what Processors (CPU), and Ram Memory are supported,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Single-Core processors.
Use a Socket 478 processor socket.
Intel Pentium 4, Celeron, or Celeron D.
(Celeron D is NOT a dual core processor)
400 to 533MegaHertz Front Side Bus processor support.
(400/533MHz FSB)
DDR Sdram ram memory that is either 266MegaHertz, or 333MHz.
(PC2100 and PC2700, respectively)
2GB's of it.
1GB for EACH ram memory slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 08, 2013 | eMachines Mb, 143159 Imperial_gv 20030812...
I have a Gateway 830GM, I was wondering if it were possible to change the motherboard so I could put a newer CPU in it? I would like to buy a core 2 duo motherboard + CPU but I am not sure if I can do that...
Desktop computer cases have standard mounting holes and screw stand offs.
There are a huge range of motherboards available, select well known brands, my favorite are Gigabyte, Intel and MSI.
Select a motherboard with the features you require. If you are into gaming, graphics/CAD then select a motherboard that does not have a built-in graphics chip, and then you can get a high end graphics card.
Most likely you need a CPU and RAM with your new motherboard.
You may also need a newer ATX2 power supply if not then check the total power requirements of the new system, it needs to be at least 10 to 15% over the total power requirements so you don't stress the switch mode power supply.
Nov 19, 2009 | Gateway 830GM PC Desktop
Highest processor for intel 810 Motherboard
i cannot give you a specific list of models but in general every pentium 3 cpu with a front side bus [FSB] frequency not greater then 133 mhz should work on that chipset. i also do not know where you could find a pentium 3 cpu for sale.
Feb 28, 2009 | Intel Refurbished DEC SYSTEM BOARD DESKPRO...
Monitor goes into 'Power Saver Mode' on boot up!
You need to upgrade your motherboard BIOS to the latest version (V.5a) to support your DUAL CORE 2.5Ghz processor... that's the problem.
Visit:
http://tw.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2779
http://tw.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=2779
Jan 07, 2009 | Corsair Memory Corsair VX 550W Ultra Quiet...
Deskpro processor
Check with your motherboard documentation.
May i know your motherboard model??
Jun 22, 2008 | Compaq Deskpro EN PC Desktop
Motherboard
Hi, this is an indication of a power surge possibly from a near by lighting strike. Always use a surge protection board. The best solution for another motherboard is to Replace it with a generic brand, if you have any doubt about the size format of the board then buy a mini ATX board and you will find this will fit any case, you do not need to buy the exact same motherboard as the orriginal one. Just make sure your Ram and CPU are the same type as needed on the new board. ie:- socket 775 CPU and DDR RAM or whatever your current board uses.
Regards mistyman
Feb 22, 2008 | Computers & Internet
LG 194wt
This is most likely not a problem with the monitor but rather a problem with the computer. do you hear the fans running in the computer? If so then the Power Supply seems to be working which would leave the most likely things are CPU or motherboard and the only way to determine which one it is would be to try the CPU on a different motherboard or try a different CPU in that motherboard.
If the fans do not run then the problem is most likely the Power Supply. The biggest problem here is that although what I have outlined is the most likely problems there are other things that could cause this and whether the fans are running or not it could still be the CPU motherboard or Power Supply. If you can I would check the voltages from the Power Supply or at least get a power supply tester to see what that shows and work from there.
Nov 13, 2007 | LG L1915S 19" LCD Monitor
Intel Motherboard Logo
137 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
