Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Dryer not drying clothes
My dryer is not drying clothes well after we moved to a new home and had it installed. its not heating up as it did and the clothes are still damp after the cycle ends. Also steam comes out when the door is opened. i clean the lint out every cycle. 4 years old and never once had a problem with it until now. Please help.
    Habit-Forming:
  • 94 Answers
An easy way to determine if proper venting is the problem is to check the air flow for the exhaust vent. While the dryer is running, go to where the vent end is on the outside of your home to see if there is a good airflow coming out with your hand. If the dryer has already heated the air should also be hot. If you don't feel a good airflow the vent hose needs a good cleaning. Keeping the vent clean and clear will dry your clothes faster and save you money.
Posted on Dec 31, 2008
Make sure that the flex hose going out from the dryer is not blocked. You should check it from both the back of the dryer and all the way to wear it vents outside. It could also be the thermostat, which is cheaper to replace than buying a new dryer.
Posted on Nov 17, 2008
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
DRYER NOT DRYING
How to check a dryer like yours with a heat problem. My home video of a Roper/Amana/Whirlpool dryer:
Oct 01, 2012 | Amana NGD5200TQ Dryer
Dryer was running longer than we thought it should. Now timer will not move and it does not dry the clothes. Could this be a switch problem or a heating element problem
Check your vent outside of your home or apartment. If you are not feeling anything heat or air, then it is clogged. Clean the vent and it should be alright. If you had on the sensor dry that could be the reason why your timer wasn't moving.
Apr 30, 2011 | Roper Dryers
DUET DRYER WON'T DRY CLOTHES ALL THE WAY THRU -
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
The dryer drum moves but no heat. Clothes do not
most of the time it is the heating coil their is a
series of springs the heat up and then the blower
sends air pass them and into the dryer to dry the clothes
you will need to remove the back of the dryer
and get to the heating element and look at it
and see it any of the springs are broken
cost for the part 80.00 maybe
good luck
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryer not completely drying clothes.
Cleaning the lint trap of the dryer may is not enough in some cases. I suspect you may have a problem with the vent ducting that extends from the the exhaust of the dryer to where it exits your home. The majority of dryer heat realted problems are due to poor ventilation and clogged vents. I dryer left in this condition will overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents.
A simple test to determine if you have a dryer ventilation problems is to remove the vent hose from the back of the dryer and attempt to dry a load WITHOUT the vent hose attached. The air exiting the back of the dryer should be warm and forceful. If the clothes dry normally, then you need to inspect your vent ducting from where it enters the wall, to where it exits the home.
If the air flow is weak and your clothes still take a long time to dry, then you need to inspect the INTERIOR ducting of the dryer. Namely, the air blower housing. I suspect you'll find your clothes will dry better with the vent hose removed. Since it dried normally BEFORE you moved, and now it doesn't, you need to take a serious look at where the vent exhausts to. If the ducting runs through and attic or crawl splace they typically development sags, kinks and can clog. The rule of thumb when it comes to ducting: the SHORTER and STRAIGHTER, the better. Every bend you put into a dryer vent creates resistance to air flow, makes the dryer blower fan work harder and creates choke points where lint can accumulate and clog. Perform this simple prelimnary check and let me know what you find. I hope you find this advice helpful.
PS Do not run your dryer for extended periods of time without the exhaust hose attached. This will add humidity to your home and potential mildew. One load should be enough to determine if you have a problem. Don't run it this way as a normal everyday routine.
Sep 08, 2008 | Whirlpool LER4634J Electric Dryer
Dryer not drying clothes properly
If the dryer heats at all and you are have to dry this long you have a blocked venting system in your home or a pinched dryer hose.
Jul 25, 2008 | Dryers
Washing Machines Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
