Question about Canon Office Equipment & Supplies
Canon iR1600-2000 PCL6 does not want too copy a standard A4 document.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
A4 is not a standard document !!!!!!!!!!!!!!!
It is European. LETTER & Legal are standard.
change paper size
Posted on Sep 08, 2008
When i press to copy it makes print but not all the page..then says load correct paper. down says A4R PLAIN COPY
A4 paper is used in Europe but some documents may be in that size. Try feeding legal size paper into your printer. Your document should be fully printed. Good luck !
Aug 22, 2012 | Canon Office Equipment & Supplies
I need instructions for copyng from A3 size in A4 size
Place A3 Document on platen glass or document feeder. Click copy ratio button. You will get 2 options. (i) Preset:- Press minus key and select 70% (ii) Zoom:- enter 70 manually Press oik Enter no of copies, press start
May 02, 2011 | Canon iR 2020i Laser Printer
While copying a written document in A4 size paper vertically, the copy is coming horizontally and it does not copy the entire page. Even the problem occurs when the paper being copied is kept...
I would look at the paper in the paper tray to make sure the paper is going in the same direction that you wont & make sure that the paper tray is set to the correct paper size. You did not give a model, so I don't know how you input the paper size. But if the image is being cut off, one of the two things I suggested will solve the problem.
Sep 16, 2010 | Canon Office Equipment & Supplies
Can any one help to find product that uses validated keypad code entry that could "unlock" the device and take copies and lock Once that is done, for canon 3300 copiers.
The Canon 9080C is purely an input device and cannot 'take' copies, however it can scan any A3/A4 document which can be printed or emailed. By printing you get the copy. Technically it is possible to control the software/Computer through Software password.
S. Mohan
Aug 29, 2010 | Canon DR-9080C Path-Through Scanner
Canon IR3300 model has some problem.
Don't recommend PCL6 for this copier. Try latest PCL5e and PS.
If that doesn't work get tech to come out and load latest firmware and see if it works.
Jul 30, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Incorrect Characters on print outs
Please reinstall your printer driver using the original media...if you are downloading the setup.exe file download it using the correct location(Region) of your city
Mar 03, 2009 | HP LaserJet P2015n Printer
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
HP Laserjet 4250 PCL6 prints only one page
Vista??? will be a driver issue, are cd drivers correct for your system?
Goto canon web download correct driver, delete old reinstall, most operating system will have this driver standard.
doubt printer problem prove by doing test prints via printers menu.
Nov 09, 2007 | HP 4250 Monochrome LaserJet Printer
87 people viewed this question
old marine
old marine
