Question about Friedrich Heating & Cooling
I need to replace a Friedrich Model number ek12J33A-3 wall unit. Its dimensions are 26" wide by 16" in height. I am having trouble finding a comparable unit that same size. Any suggestions would be appreciated. Thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
As long as it fit inside the wall , go smaller and close the hole, or slide the new unit in the old case. & sealthe loose ends . or keep callng around..
Posted on Sep 08, 2008
I need the cutout and overall dimensions of a Whirlpool Oven/ Microwave combo unit Model RMC275PD?
Cutout
25 3/8 width
41 inches height
23 inches depth
Overall
26 3/4 width
42 7/16 height
Apr 19, 2016 | Whirlpool Microwave Ovens
How many 16in blocks do I need to cover a 52ft × 2.5ft wall?
not enough details
to get an answer the block dimension has to be known
the 16 in" dimension could be either height or length but the other dimension is needed
however just to help you get your own answer
the wall is 130 sq feet in area
the block is 1.3 ft X A ( A being the missing dimension in feet)
you then divide 130 by the product of 1.3 times A in sq feet and that will be the number of blocks
Jun 20, 2015 | Garden
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
Digital keypad does not respond on Friedrich through the wall AC ("Weathermaster). If I hold down the "cool" button for several seconds, I get E-2 display.
First, check the reset switch on the power cord. If after holding it in for 2 seconds, the unit does not reset itself, it means that you will need a service call. In addition, I have looked over the Owner"s Manual for you model, as well as the Service Manual and no where can I find a reference to an E-2 display on your LED screen. If resetting the unit does not solve the problem. Contact Fredrich's Customer Support Dept (800) 541-6645.
Jul 06, 2011 | Friedrich CP08N10 Thru-Wall/Window Air...
What is the size of this air conidotioner model number ESA3109-L
Do you mean the amount of energy that it uses? It is a 10,200 BTU air conditioner and is recommended for a space of 475 sq. ft.
If you mean the dimensions of the window unit itself when installed, then the space between the window casings must be between 24 1/2" and 38" wide. The height is 14 9/16" and the depth is 20 5/32". The AC unit itself is 14 3/8" x 19" x 20 5/32". See page 15 of the manual (16 of the pdf) for the entire set of dimensions.
Retrevo has the manual avaiable here: http://www.retrevo.com/support/Haier-ESA3109-L-Air-Conditioners-manual/id/23148bh150/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
May 25, 2011 | Heating & Cooling
I have Freidrich model #SC06H10D through the wall unit. I need new unit, but it has to be same dimensions as this one which is about 14 3/4" wide. Do you make one to replace this??
The FixYa website does not make or sell appliances or repair parts. What we provide is information on how to troubleshoot and repair all types of things. And sometimes, find things. With that said, here is a link to an identical (Model # ) to the one you want to replace. http://www.ajmadison.com/cgi-bin/ajmadison/SC06H10D.html
Good luck, I hope this helped you find what you're looking for.
Apr 14, 2011 | Friedrich Heating & Cooling
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
180 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
