Question about U-Line 75R Refrigerator
U-Line 75R Regrigerator
Cooling plate in refrigerator is iceing over with white ice.
  • 93 Answers
Most cases is bad temp control (90%) or door gasket has a open gap.
Posted on Mar 02, 2010
Freezer is working, regrigerator is not cooling, icing up on the inside panel,
most likely have a defrost issue...need to remove back panel and check heater and defrost thermost you willneed a meter to check continuity good luck to you
Jan 06, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice maker is not working on my whirlpool side by side regrigerator
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
45ts
Aug 06, 2010 | Whirlpool ED2FHEXN Side by Side...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our 2 door water dispensor not working. ice coming through o.k.
I followed a suggestion from one of your customers and it worked!
JKP
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid KSRG25FKSS16 Side by Side will not make ice
First I would check for obstructions in the line from the water inlet valve to the tray assembly. If thats good check the valve it self. This is a double valve, it supplies water to the door and it supplies water to the ice maker. Check and compare both coils. They should be around 300 Ohms. If not, replace it. Try Partselect.com
Oct 10, 2009 | KitchenAid Refrigerators
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
U-Line outdoor frig not cooling properly
check timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 don't damage coils
Aug 22, 2009 | U-Line 75R Refrigerator
Regrigerator isn't cooling - freezer is fine....
Make sure there is not a ice build up in the back wall of the freezer.
If so, you have a defrost issue.
Make sure the freezer fan is blowing.
If so, you have a thermistor issue.
Feb 22, 2009 | Amana ABC2037DTS Stainless Steel Bottom...
Jenn-Air Refrigerator Not Cooling
As others have noted, the solution is counter-intuitive but easy. The refrigerator keeps cold on this model by cold air coming over from the freezer side. So most likely it is ice blocking the freezer coils or the fan that moves the air. So turn off the freezer and defrost it. You will need to remove the big white plate on the back of the freezer (on the inside) to most effectively get the ice to melt. You can use a hair dryer for this, or just leave the freezer sitting with the door open for several hours.
Jul 09, 2008 | Jenn-Air JCD2389G Side by Side...
U-Line 75R Refrigerator Logo
113 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
