Question about Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 will not print after cleaning of ink heads.
Cartridges have been cleaned and ink is at 3/4 full. What else can I do to get it to print correctly in color.
  • Anonymous Oct 03, 2008
    My printer will not print any color items. It doesn't seem to recognize the color cartridge. I have cleaned the cartridges. I also switched cartridges but the ink levels do not change. No matter how old or new the cartridge is the printer still shows it as 1/2 full on the ink levels. Any ideas?
  • Lexmark Master
  • 4,338 Answers
Service manual:
http://www.nodevice.com/manual/newmans/lexmark/4408smpdf/get21352.html
Please remember to rate all users who assist you for free :)
Posted on Oct 02, 2008
Lexmark x6170 not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
My Lexmark X6170 is smearing all images that are about a third of the way down the paper. Everything else is printing fine.
Try to clean the cartridge nozzles using the printer control panel.
  1. Load paper.
  2. Press Copy.
  3. Press Options until Maintenance appears on the display.
  4. Press the right arrow until Clean Cartridges appears on the display.
  5. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  6. Print your document again to verify that your print quality has improved.
Also, check your ink levels. Make sure your ink levels are substantial for printing.
May 18, 2011 | Lexmark X6170 All-In-One InkJet Printer
How do i clean the heads on my lexmark x4580 printer the black is not printing but the colour is ok and the cartridge is full of ink cheers
  • Hello,
  • Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
  • (1) Open the printer and wait for the carriage to slide over
  • (2) Remove the ink cartridges from the print head.
  • (3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head and the electronic contacts on each ink cartridge.
  • (4) Repeat this until there is no ink residue coming off on the cotton swab.
  • (5) Once finished, allow to dry and replace the cartridges
  • (6) Try to print something now
  • If that does not work then you have one of two possibilities:
  • (1) One of the ink cartridges is defective and causing the error
  • (2) If it's definitely not that, then the print head will need to be replaced.
  • Thanks
Mar 10, 2011 | Office Equipment & Supplies
I am unable to find color ink for my lexmark x6170. Additionally, are all the inks the same (quality)?
Lexmark X6170 uses these two ink cartridges: -
Black Print Cartridge (18L0032E)
Colour Print Cartridge (18LX042E)
It is highly recommended that you use the original cartridges as the cartridges and ink vary from printer to printer.
However, if you are unable to find the cartridges, you may look for refilling option.
CreativeTECH
Jan 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
DOCUMENT DOES NOT PRINT IN COLOR - INK CARTRIDGE IS HALF FULL
It sounds like you are using aftermarket or refilled cartridges. Aftermarket cartridges will sometimes gum up or clog the nozzles. To clear the sensors and nozzle, install new OEM cartridges, run deep cleaning a number of times (at least 3 times), and then the alignment utility.
Aftermarket/refilled cartridges do not always meet the manufacturer's specifications for quality. Try cartridges from LDproducts.com for your printer. I've never had a problem with their aftermarket cartridges.
Please rate this solution. Thanks.
May 10, 2010 | Lexmark X6170 All-In-One InkJet Printer
Cleaning nozzles without using a computer
Good day. Yes, it is possible to clean the nozzles of the cartridges using the buttons on the printer. Just follow these steps:
1. Load paper in the printer feeder.
2. Press Copy.
To print a test page using the buttons, follow steps 1-3. Then, press the right arrow until Print a Test Page appears on the display. Press select.
Hope this helps.
Mar 16, 2010 | Lexmark X6170 All-In-One InkJet Printer
Full cartridges and it won't print. lexmark z611
A friend uses methyl alcohol to clean printheads but I don't know how. Perhaps he fills an empty cartridge...
I watched a guy professionally filling cartridges and he used steam to clean those with a printhead.
Printers that have the printheads in assembly instead of integrated into the cartridge can be difficult. Epson are like that and if not in regular use and always with a good supply of ink the printheads dry out and become blocked. The Epson service engineer told me it would be completely uneconomic to dismantle the printer and repair.
I expect it is a similar story with many printers that make a cheap ink claim. Cartridges that have the integral printhead are more expensive but seem less trouble overall.
Sep 17, 2017 | Lexmark Z611 InkJet Photo Printer
My lexmark printer series 6170 will not print.
For the tech to give you that response was indeed to the point, but of little use to most people.
There is a nozzle cleaning utility in the Lexmark Solutions Center. Use that to clean the nozzles of your ink cartridges. The Lexmark Solutions Center is installed on your computer. You can find it in the Windows Start Menu under "All Programs" in a folder marked "Lexmark".
If your printer has been sitting without use for more than a few weeks, the nozzles may be too clogged with dry ink to clean by conventional means. The only thing left to do is to replace the ink cartridges.
May 19, 2009 | Lexmark X6170 All-In-One InkJet Printer
Not printing...printer says remove or change ribbon
First you want to clean both the cartridges and the cartridge seats inside of the printer with warm water and a soft cloth (I use old t-shirts). After you've done that place the cartridges back into the printer and clean the printheads. You can do this by following the steps on page 83 of your user manual:
1) Load the paper
2) Press "Copy"
3) Press Options until Maintenance appears on the display.
4) Press the right arrow until Clean Cartridges appears on the
display.
5) Press Select. A nozzle page prints, forcing ink through the
6) Print your document again to verify that your print quality has
improved.
You can also find information on cleaning the cartridges on pages 83 and 84 of your manual. If you don't have one available, you can download one at:
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
I hope this helps!
Dec 11, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
172 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
