Question about Saeco Talea Touch 14-Cup Coffee Maker
Talea Touch - Drip Tray not raising/lowering smoothly
Saeco Talea Touch - Motorized adjustable drip tray is no longer raising and lowering smoothly. It "catches" on the way up and done. Unit is less than a month old...
  • 515 Answers
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
Posted on Sep 08, 2008
My Talea touch plus is struck in the cleaning cycle after a de-scaling.
Normally it drips at the beginning and then becomes a steady stream throughout the shot. The truly determining factor is how fast the shot is coming out. You want to get 2 to 2 1/2 ounces of espresso in 20 to 25 seconds. If it's coming out that slow it's going to be a lot longer, and odds are the grind is still a touch too fine still. Sounds like you need to just tweak a bit to get an even better shot. Also, keep in mind with the Saeco supers, there is a 2-3 shot delay in changes you make in grind before it makes an effect.
Jul 22, 2012 | Saeco Talea Touch Plus Automatic Espresso...
Hi, I have a Saeco Talea Giro Plus machine and have only used it a few times. Now the alarm light is permanently on, but the machine has enough coffee and water and the drip tray and dregdrawer are empty....
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
Jul 03, 2010 | Saeco Talea Giro Espresso Machine
How to remove drip tray
Hi
Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
Apr 20, 2010 | Saeco Royal Cappuccino Espresso Machine
I have a Saeco Talea. The drip tray will go up
Probably the touch pad is faulty. Before we decide that make sure the bottom touch area is dry and nothing sticking on to it.Can be check by removing the 2 screws underneath.
The worst case senerio will be the CPU which is not receiving the signal from the touch pad.
Jan 10, 2010 | Saeco Talea Ring Plus Espresso Maker with...
How do I remove the drip tray on the Saeco Talea Giro?
I have a Talea Giro. To remove the drip tray, just pull it off. I pull from the centre
Nov 09, 2009 | Saeco Talea Giro Espresso Machine
Insert Drip Tray
Check the right side of the tray holder. There should be a small lever (micro-switch) that you can feel and press in. If it does not click when pressed then you need to replace it at a service center. If the leaver just broke off (a small triangle piece with a tab on the end) then you may be able to stick a piece of card board to make the switch click and fool the machine to think the tray is in. until you can get it to a service center. ukeboy@pixi.com
Dec 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Touch 14-Cup Coffee Maker Logo
244 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
