Question about Clarion DXZ838RMP CD Player
4 rear speakers have no sound
The back 4 speakers stopped working on our boat this week end
2 Suggested Answers
SOURCE: How do you adjust the front/rear balance?
push the A-M button on the face until you see balance then use the left and right buttons you would normally use to rewind or FF....
Posted on Jul 27, 2010
Speaker hook
Hi it's a problem in the set up . This model , like few other in the line have the possibility to switch the "back speakers" ( through harness or RCA) into "BASS SPEAKERS" what give you a possibility to hook up a Sub without an extra amp .
To switch it back just follow the Section 2 / Sw control of this link http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-3300UB_OwnersManual0902.pdf
Dec 19, 2013 | Pioneer DEH-3300UB Radio-CD-MP3-Digital...
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
In my boat is a Clarion CMD6 head unit with two rear CMQ1620R speakers, it distorts at medium to high volume, you cant turn it up load when going.Wishing to put two new speakers in the front, cannot cut...
Best bet is to take your boat to a qualified Marine Audio dealer (generally not a boat repair shop or marina), or to a good quality Car audio store that is insured to work on boats (separete insurance usually).
When it comes to boats, you need lots of power and speakers.
First thing to do is make sure what you have is properly installed. Then determine what is "distorting" .. is it too much base, purely volume or what.
Most boats we do (wakeboard style and river boats) we do: 40-75 watts RMS per speaker 4-6 speakers in boat 1 10" or 12" sub with 200-300 watts RMS Tower speaker if requested with 75-125 Watts RMS per speaker
Feb 06, 2011 | Clarion Car Audio & Video
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
I have 4 wires, red (power(, black (ground), green (speaker), gray speaker...the stereo has these same color wires...so I connect the corresponding color. The boat has NO yellow battery wire that is on the...
(http://inform3.kenwoodusa.com/manuals%5CKTSMP400MR.pdf )
Here's a link to manual and wiring on page 30 on the PDF file.
Yellow is constant power from battery, for memory etc. Red should be to switched source.If need be, you can connect both to battery, but remember, you'll have constant power draw on battery when stereo left on but switch turned off, and will draw battery down, if you forget to shut it off, and leave the boat. Speaker negatives to black should work but I would advise hooking my 2 right and 2 left + speaker wires from stereo together, then to one of the speaker positives,right or left for better sound. Fronts will usually supply higher ( high and mid range), and rears will supply lower sounds (woofer) Joining them together will give better sound usually, when only using 2 speakers, on a 4 speaker stereo. You may want to test with them joined and not, to see what sound you like better.
Sep 26, 2010 | Kenwood KTS-300MR CD Receiver
Can't get sound to come out of rear speakers.
go to the menu and select fade f/r then adjust until happy should be in the middel
Jun 13, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Mar 30, 2007 | iLO XM-MP3-CD Car Stereo
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Clarion DXZ838RMP CD Player Logo
22 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
