Question about NetGear CG814M Wireless Cable Modem Gateway Router
Cannot Log on to my Router - NetGear CG814M Wireless Cable Modem Gateway Router
Pinging google.com [64.233.187.99] with 32 bytes of data
Reply from 64.233.187.99: bytes=32 time=1310ms TTL=242
Reply from 64.233.187.99: bytes=32 time=3886ms TTL=242
Reply from 64.233.187.99: bytes=32 time=2985ms TTL=242
Request timed out.
Ping statistics for 64.233.187.99:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss)
Approximate round trip times in milli-seconds:
Minimum = 1310ms, Maximum = 3886ms, Average = 2727ms
jatinder_uppal11@yahoo.co.in
Posted on Nov 22, 2007
    Novelist:
    Scholar:
  • 123 Answers
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thid=102071&prdid=252225) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Posted on Feb 19, 2006
How do I log in
To help you do understand, how to log into routers. You need to know the router model name and number and then you can search for routers default i.p address to access the log in page of the router. After that, you need to put the default Username and Password of the router. For example, if you are using Linksys router then find the link given below and follow step-by-step instructions on it:
http://www.wikihow.com/Log-Into-a-Linksys-Router
GuruAid.com
Jul 11, 2016 | Computers & Internet
How to log in dlink
How to Log In to Link Wireless Router eHow
  • Share
  • ? Tweet
  • ? Share
  • ? Email
Save Be the first! To log in to your D-Link router and change its settings, visit the router's Web interface and log in with the administrative password. You can usually find the interface address and the password on the bottom of the router or in the manual. The most common addresses are 192.168.0.1 and 192.168.1.1, and most D-Link routers either use the password admin or have a blank password by default. If your router also asks for a username, use admin.
"" frameborder="0" marginwidth="0" marginheight="0" scrolling="no" style="border: 0px currentColor; border-image: none; vertical-align: bottom;"> Promoted by
Step 1: Log In
Visit the router's interface address, such as 192.168.0.1, in any Web browser on a computer connected to the router. If you plan to make changes to your wireless settings, use a computer with a wired connection to avoid getting disconnected after each change. Enter your password -- or leave the box blank for routers without a password -- and click Log In.
Read more : http://www.ehow.com/how_8404370_dlink-wireless-router-login.html
Oct 27, 2015 | Computers & Internet
How to do i put a pasword on wifi
You have to log in to your router meaning you need the username and password usually
admin
password
to log in pull up browser type 192.168.1.1 which is usually routers ip addresses by default
log in trying the option I gave if you didn't set it up in the first place
and create a password for log in. I would need more information about your router to help more
Sep 03, 2014 | NetGear WGR614 Wireless Router
Forgot my securty key for zyxel p66ohw
Log on to the router by typing the IP address into a web browser. This will log you into the router.
Once logged in you can select the "security" section and find your security key.
If you no longer have the password to log in you will need to reset the router. You can reset it by pressing a pin inot the pin hole on the back of the router near the AC adapter plug.
Thanks
Jun 07, 2010 | Zyxel P660HW-D1 Router
Hello sir/madam i have problem with D-link router i never change password but now i can not log in the old password why?
Hi do you mean log in to change routers settings or connect to the network which is broadcast by router. If you mean first log in to router settings etc. If your old password don't work you should find a reset button somewhere on router if you press it it will take router to default settings and you can use default user name and password to log in. If you mean connecting to the network you should go to the settings of your router connect to the router by network cable and put 198.162.1.1 in your internet browser put your username and password (which you can find in manual or on internet (just google "D-Link DI-624M Router default username password) and check what password is and change if you like. You should find it in wireless----> security settings. Good luck and please don't forget to let me know if that was any helpful.
Apr 23, 2010 | D-Link DI-624M Router (DI624MRE)
I am trying to reset the default log in on linksys befsr41 router
If you want to reset the router to its default log in , the only way to do that is to manually reset the router by pressing the reset button of the router for 10 seconds while power is ON and after that the log in of the router will be back to its default log in the username is blank and password is admin
Nov 25, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Actiontec router log behavior
The router does store the information in itself. The router has a small region for storing information on operations and logs. That log might be accessible from the router's control panel. However, every router is different and therefore I can't guarantee that your router will allow you to view its log.
Most likely the router will store the log in the same area used to store the Router's firmware. This is a relatively small storage chip with just enough space to support the firmware of the router, the router's control panel source files, and the log.
Let me know if I can explain anything mentioned above in more detail or if I can assist you with anything else.
May 13, 2009 | Actiontec (5GE583000-01) Router
Cannot log into internet after reseting the router
well resetting the button at the back of the router makes the router go to factory default settings.As such you need to configure the router once again as per your service provider's settings.If you already have the IP informations and the other informations.You can try to log into the router using the default IP of 192.168.1.1 which would take you to the router home page.You can configure the Router and save the same.Once done you should be good to go.
Apr 13, 2009 | NetGear DG834G Router
Unable to log into router to open ports
To log in to the router in order for you to do a port forwarding you can follow the steps from this link, but if the default username and password didn't work reset the router so it will be back to its default settings http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-T1v2/Age_of_Empires_III.htm
Oct 24, 2008 | Zyxel P660HW-D1 Router
Activity log
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Status tab and then click Log to the left. This page displays the activity log for your wireless router. The buttons located above the log can be used to perform the below actions: First Page - View the first page of the log. Last Page - View the last page of the log. Previous - View the previous page of the log. Next - View the next page of the log. Clear - Clear (delete) the entire log. Log Settings - Configure advanced options for the activity log.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
NetGear CG814M Wireless Cable Modem Gateway Router Logo
189 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
