Question about HP DeskJet 3820 InkJet Printer
Blank page I have this printer attached to an ophthalmis machine which has no screens to be able to ask it to do things. I only have the buttons on the front to work with. I have not used the printer for 10 days and the service chappy who has mended my machine it is attached to thinks I need to clean the print head. How do I do this? Or do I need to try something else?
    Novelist:
  • 100 Answers
You can run a self-test independent of the device your printer is attached to:
1. Turn the printer ON.
2. Press and hold the POWER button.
3. Press the RESUME button FOUR times.
4. Release the POWER button.
If that works, I would suggest taking a laptop or small PC to the printer and hooking it up. Try printing from the laptop. Let me know the results and we'll go from there.
Regards,
Char1ieJ
Posted on Nov 18, 2008
Why am i getting blank copies from my printer
The chances are good that what U need to do is a printhead cleaning. On the printer if it has a LCD screen scroll through the menus and look for Maintenance or tools and then look for printhead cleaning . It can also be done through the software by going to the top left hand corner of the page U are trying to print and click on the button or File scroll down to print and click on that and that brings up a box with your printer name in it and beside that is a box called properties and look for maintenance or tools there. After the printhead cleaning it will ask if U want to print a test page - say yes if that page looks good -problem solved but it will probably take a few cleanings if U R getting blank pages now. Warning repeated cleanings use a lot of ink so only do what you need to. If after several cleanings U are still getting blank pages U might need to replace the printhead
Aug 03, 2014 | HP Business InkJet 2800 Printer
Portion of page prints blank
Press the Ink button -> Test Print -> then choose Print Quality -> the printer will then go through and print a series of small squares in each of the four colors in the shape of parallelograms. If you see any gaps in parallelograms then you will be asked asked to clean the cartridge, do so. -> Just keep repeating process until there are no gaps
Then I did an Alignment check right after the cleaning through pretty much same process:
Press Ink button-> Test Print -> then choose Alignment-> and make sure the patterns match to the closest number
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 27, 2014 | Brother MFC 9700 All-In-One Laser Printer
The printer sounds like it is printing but the page comes out blank.
Problem Blank Pages; Blank Print Out Solution
Symptom
When printing from the S or Pro Series printers, you may encounter blank pages being printed.
Solution
To rectify this issue, please follow the troubleshooting steps below:
Action Image 1
While on the main screen of the printer, open the cover.
  • If the printhead stays to the left, go to Step 2.
  • If the printhead comes to the center, do not continue troubleshooting because the printhead is faulty.
ss_mainscreen.jpg 2
Place the printer into "Replace Printhead" mode using the Maintenance menu. To access this mode, follow the steps below:
  • Touch Screen Printers:
    • Tap on the Ink Levels icon.
    • Tap on More Options.
    • Select Replace Printhead.
  • LCD Screen Printers:
    • Press the Setup button and use the arrow buttons.
    • Select Maintenance.
... 3
Open the covers and look into the printer on the left-hand side where the cartridges are inserted into the printhead - aWICKING PAD is located there.
  • If this PAD is BLACK (as seen in the right-hand image; click it for larger view), then the printer has successfully gotten ink into and through the printhead.
  • If the PAD is WHITE, then the printer has not been able to make the ink flow through the printhead. Go to Step4.
pad.jpg 4 Seat the printhead again. Unpower the printer and connect it again. Open the cover and reseat all four tanks. Press firmly on the rear of each tank and make sure all four snap in tight. ... 5
Insert plain paper and run Deep Clean.
    • Select Deep Clean Printhead.
    • Press the Setup button.
If you cannot get all four inks to lay clean, identify which one, if any of them, is failing.
  • If there is just some ink on the page - run the Deep Clean again.
  • If there is no ink at all, then the printhead is faulty.
Jul 17, 2011 | Lexmark Prospect Pro205 Wireless...
Lo'st cd so cannot install printer on new laptop
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Dec 02, 2010 | Lexmark All-in-One Printer with PictBridge
Printer will not print with black ink. For normal printing, from any source, there is no black ink delivered to the page. When I "print report" or "Clean Printhead", I get a page with nothing on it but...
The issue may be corrected by following steps to perform a reset on the printer,
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
For Box-type models:
1. Unplug the power cord from the printer.
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
If the above doesn't help,try
  1. Press Cancel and Power, at the same time.
  2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
  3. “Support Menu” should appear.
  4. Go to Resets menu and use the semi-full reset.
Or
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new
This should correct the issue.
Thanks & regards, Techbuddy247
Jun 03, 2010 | HP Photosmart 3210 Printer
Canon bcj-80 prints blank pages
The problem comes mostly from the printhead. It helps to put a drop of water on the cleaning pad over to the right where the printhead parks, before doing a clean cycle.
Jul 01, 2009 | Canon BJC 80 InkJet Printer
No print at brother mfc-24c
"Machine Error 50" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
However, if that doesn't work, the error is mechanical, and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Faxes come through blank
The machine USUALLY tells you you are low on ink. It 's possible one or all cartridges are dried up.
Dec 21, 2008 | HP 1040 Plain Paper Inkjet Fax
Xerox 8500
I've seen this with copiers in that a one second power failure and I need to reset it from the diagnostics menu. I have also seen this on printers as well. Here's the instructions for getting to the diags menu
Press and hold the red button (info button) and the “OK” button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the “Enter Diagnostics” menu. Select the “OK” button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select “ok” again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 “no test selected”
4) 7) It will ask for a confirmation. Select “OK” to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. “Exit diagnostics.”Select “OK”.
9) It will ask for a confirmation. Select “OK” to confirm.
10) At this time the printer will again reboot for several minutes & then should come up to a ready to print.
Dec 03, 2008 | Xerox Phaser 8500/DN Printer
HP DeskJet 3820 InkJet Printer Logo
Seeker5211
Seeker5211
