Question about HP Color LaserJet 2600n Printer
Color problems we also do refilling for 1600 end the colors is to bad the red color
  • HP Expert
  • 141 Answers
Almost all remanufactured magenta toners have problems in my experience.
Posted on Sep 20, 2008
Printer HP Color Laserjet 2605dn printer is not giving the color prints correctly. The colors are very fade, only black color is fine, rest all color combination are very light.
Your problem have only one solution - open laser/scaner Assembly carefully and clean all mirrors inside whit dry cloth. Dirty mirrors is the most frequently problem for 1600/2600 series
If you dont know how to do that just visit HP service
Mar 31, 2011 | HP Color LaserJet 2600n Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
Will not print blue? HP 2600
SPACILLY FOR HP PRINTERS DONT USE THE REFIL CART
this problem due to refill cart replace with new one ur problem will be resolved
Jul 01, 2010 | HP Color LaserJet 2600n Printer
COLOR PRINTING ISSUES. COLOR IS PRINTING LIGHTER ON ONE SIDE.
check your toners
if your toners are refilled
the drum or the magnetic roll of the refilled toners must be replaced
Apr 26, 2010 | HP LaserJet 1600 Printer
Will not print true colors especially red and blue and green
replace the two ink caterage to a new one. it could be from the ink you refill that is if you refilled. bye
May 22, 2009 | Compaq Inkjet IJ600 Printer
Red color on hp 1600 not work fine
1. Turn off the printer.
2. Press and hold the (Select) and (Cancel Job) buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init displays, release the (Select) and
(Cancel Job) buttons.
When the NVRAM init is complete, the printer will return to the Ready state.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Can't print just black when out of color with Samsung CLP-300
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour cartridge.so you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
thanks.
Dec 14, 2008 | Samsung CLP 300 Laser Printer
How to refill canon pixma ip1600 ink colour? the hole is too small.
IF YOU HAVE BUY THE INKS THEN YOU GET NIDLE AND SIRING THEN YOU WILL USE THE TECHNIC DOCTOR USE TO SWAP THE LIQUID FROM THE CONTAINER AND INJECT IT IN THE BODY YOU WILL USE THE SAME TECHNICS GET THE INK IN TO THE SIRING AND PUT IT IN THE CARTRIDGE BUT MIND YOU LOOK AT THE HOLES VERY WELL RED HOLE WILL BE MARK RED, BLUE WILL BE MARK BLUE WHILE YELOW WILL BE MARK YELOW SO ALL YOU NEED TO DO IS FOR YOU TO PUT THE INK IN THE RIGHT HOLE IN SOME CARTRIDGE THE HOLES WILL GUIDE BY A OBJECT REMOVE CAREFULLY THEN AS YOU FINISH REFILLING EACH HOLE PUT THE OBJECT BACK.
Nov 13, 2008 | Canon PIXMA iP1600 Printer
Canon iP 1600
dear
you can refill your catridge, open the label .... make a whole with knife or something edge, and the red color in center position, the yellow in the right position , and the blue in the left position
don't refill too full, about a 30 cc inks
oke maybe it can help you
thks
cropp
Feb 19, 2008 | Canon PIXMA iP1600 Printer
Color
I am assuming from your brief problem description that you are getting bad colors when you changed your color cartridge. Are you using a new and certified HP ink cartridge? Are you doing a refill of your old ink cartridge or have bought one of those "re-manufactured" cartridges? The head in the cartridge is very sensitive - when they are damaged or poorly handled - it could result in cross contamination of the color inks. Hence - the brownish color you see could be the result of that cross-contam. My impression is that the remanufactured or older or continously refilled cartridges may be more prone to getting damaged - maybe bec of inherent wear out. Hope this helps.
Nov 30, 2006 | HP DeskJet 3325 InkJet Printer
HP Color LaserJet 2600n Printer Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
