Sc545 code apear after replasing heater unit it is stell what is the sd codes Receiving error code SC545 for a Ricoh Aficio AP610N Turned off / on - checked obstructions (none found) Please assist.
In this case, IT support staff corrected. Not sure what solutions or actions they took.
Posted on Sep 09, 2008
Ricoh 410 DN SC545 error code
This is a code for fusion.
- Thermistor
- Thermostat
- Lamp
Dec 30, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
I need help on how to disable the functional code sc545 with my dsm622 ricoh aficio 2022 copier
Thats a fuser failure code. I suspect your upper roller is bad and has loaded up the temp sensor. The sc545 is dangerous to play around with, a possible fire danger has occured and the machine has locked you out. This requires a tech to inspect and reset. Ricoh does not allow qualified/certified technicians to disseminate this information out to the customers due to the dangers involved.
Jul 28, 2009 | Ricoh Office Equipment & Supplies
Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
Jun 16, 2009 | Ricoh Aficio AP410N Laser Printer
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
The middle thermoster in the fuzing unit (heater )is out of position or something is obstructing it from reading the temperature on the hot roller , or the thermoster is faulty
Nov 06, 2007 | Ricoh Aficio 2027 All-In-One Laser Printer
886 people viewed this question
