Question about NetGear CG814M Wireless Cable Modem Gateway Router
How to Find the Ethernet Adapter's MAC Address
    Novelist:
    Scholar:
  • 123 Answers
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Posted on Feb 19, 2006
Connect network wireless
If you are using this as ethernet adapter, there definitely are IP addresses for each cable plugged into the router. Your MAC needs an IP address for the router to ROUTE the traffic to and from the internet. That's what Routers DO. Listen to your Support. Unplug all other devices from the router you connect to, then connect your adapter, and let the router assign an IP address to it. Then connect the rest of the devices one at a time, and see if that works. Make sure you plug the cable from the efibre to port #1 on the router, for highest priority of traffic.
Sep 13, 2013 | EMC LightPulse LP11000-E Fibre Channel...
How to change my ditto mac address
The following procedure worked for me :
To change the MAC address of a Dane-Elec MyDitto Classic NAS, use the flash memory configuration hidden page :
http://(ip of your my-ditto)/flash.asp
- Enter the right MAC address (which is written on a sticker, under your my-ditto NAS... something like "001F1Fxxxxxx") in the field "NIC0 address:".
- Click the "Save settings" button. (The same page reloads, with empty fields : ignore it).
- Restart your my-ditto NAS (with the power switch).
After booting, the power led should stop blinking (stay lit), and your NAS should be available through PC client software (master/user usb keys) again.
If the problem remains or reappears (dummy MAC address again), the culprit could be the CR2032 lithium backup battery inside your my-ditto. In my 2-year-old NAS, this battery was too low (2.1V instead of expected 3V). To replace this battery on its socket, you have to open your NAS (voiding the warranty).
Good luck...Hope this helps someone !
cvoila
Sep 26, 2012 | Dane Elec Dane-Elec myDitto 1TB 2-Bay Home...
How do i find out what my mac and ip addresses are?
Windows XP
  • The host name is your computer's name
  • Click the Start icon
  • Click Control Panel
  • Select Classic View
  • Click Network Connections
  • Right click on the connection you are trying to find the MAC address for and select Properties - you will have a separate MAC address for your wireless card and your Ethernet (LAN) card. Make sure you use the correct one.
  • Hover your mouse over the text box underneath connect using. Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your computer on AU network you will need to register this MAC address
Apple Mac OS X (Tiger)
Information Services does not provide support for the use of Apple Macs. However you may find the following instructions useful if you wish to use your Apple Mac on our network
  • From the Apple in the upper left hand corner choose System Preferences
  • Click on the Network icon
  • From the Show menu Select Airport (for Wireless) or Built in Ethernet (for Wired)
    • For the Built in Ethernet (for Wired) the MAC address will be at the top of the Ethernet tab as the Ethernet ID.
      The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
    • For the Airport (for Wireless) the MAC address will be at the top of the AirPort tab as the AirPort ID (or on the TCP/IP tab, again as the AirPort ID ). The MAC address is the 12 character address e.g. 00:14:67:F0:56:A4
  • To find your Computer Name go back to System Preferences and click on Sharing , your computer's name should be in the computer name box at the top of this window.
Apple Mac OS X (Snow Leopard/Leopard)
  • Select Ethernet for Wired or Airport for Wireless
  • Click on the Advanced button
  • Click on the Ethernet tab
  • Your MAC address will be at the top of this window as your Ethernet ID . The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
Linux
  • In a privileged terminal session type: ifconfig
  • This will show you a list of the network adapters installed. The MAC address is referred to here as the HWaddr
  • If you have a wireless card you will see more then one MAC Address, make sure you register the right MAC address.
  • To pick out your wireless MAC address type: iwconfig - your Wired one will be the other one
Vista
  • Click Network and Sharing Center
  • Select Manage Network Connections from the list on the left hand side
  • Hover your mouse over the text box underneath connect using . Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
Windows 7
  • Select Network and Internet
  • Select Change Adapter Settings from the list on the left hand side
    You will have a separate icon for your wireless card; your Ethernet (LAN) card and your Virtual WiFi MiniPort adapter (if you have one), each with their own MAC address. Make sure you select the correct one.
Nokia mobile phones
  • On the home screen, enter *#MAC0WLAN# or *#62209526#
  • Your MAC address will appear as a popup and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your phone on AU network you will need to register this MAC address
http://whatismyipaddress.com/
You can use this link to find out your IP address
Good Luck
Dec 06, 2010 | Computers & Internet
My router is not obtaining an ip address through WAN port. I use my rouders WAN MAC Address to identify my rouder to my ISP provider. I can see this MAc address under Internet Connection on the rouder...
Try using the MAC address of the ethernet adapter and clone it to your router. Your ISP might be recognizing the MAC address of the LAN card of the computer.
To get the mac address of the computer go to the command prompt and type ipconfig/all.
You may also need to contact your ISP to clear arp in their end, so that they will detect that you have a router. I hope this helps!
Feb 12, 2010 | Computers & Internet
Cannot connect the 2nd computer to the internet using the ethernet adapter
Most likely, your ISP only allows a single MAC address to connect to them. To make this work with multiple computers you'll need a router that can do MAC address cloning, i.e. it reads the MAC address off of the computer that works and presents this to the ISP in all cases even when the request comes from different MAC address.
The MAC address is unique and set at the factory for each ethernet card so it's not something you can or should attempt to change. If you were able to change the MAC address on the second computer to match the first you would break your network rather than fix the problem.
It is also possible that you are using fixed ip addresses and simply need to configure the NIC on the new computer. If you check the IP v4 settings for the old computer and they have an explicit address for the card then this is is the issue. If so, simply configure the new computer to match the old computer but make sure the last of the four numbers in the ip address is something between 1 and 254 that does not match the first computer or the gateway address.
Oct 04, 2009 | NetGear Powerline XE102 Ethernet Bridge...
Can't find my MAC address
Hi, here is a solution for your problem: Obtaining your MAC address
Your MAC address will normally be on the box or registration card for your computer or individual ethernet card. If you can not find it, please follow the instructions below depending on your operating system.
Windows Vista:
  1. Click on Start Button.
  2. Click on All Programs.
  3. Click on Accessories.
  4. Click on System Tools.
  5. Click on System Information.
  6. Click on plus sign in front of Components.
  7. Click on plus sign in front of Network.
  8. Click on Adapter.
  9. Scroll down to your Network Interface Card and it will list the MAC Addresss. (Make sure you do not get the wireless adapter).
WINDOWS NT, 2000, or XP:
  1. Using your mouse, click on the Start Button.
  2. Click on Programs.
  3. Click on Accessories, and then Command Prompt.
  4. Once a small black window appears, type in ipconfig /all (with a space between the g and the /).
  5. Locate the number to the right of Physical Address. This is your MAC address.
WINDOWS 95/98/ME:
  1. After clicking on the Start Button, click on Run.
  2. In the white space of the window, type in the word winipcfg
  3. Click on "OK".
  4. Look under the info for the Ethernet adapter. (Your system may also have a modem.)
  5. The number next to "Adapter Address" is your MAC address.
Hope this helps.
May 10, 2009 | Computers & Internet
Wrong Kind of Ethernet Cable?
If you can still access the web based configuration on your linksys router (by going to 192.168.1.1 in your web browser) that means nothing is wrong with the cable/connections. However the ISP is not letting your router get access to the router since it doesn't have the same MAC address as your computer's ethernet card/port.
To change your routers MAC address to the sameone on your computer (So you ISP thinks its still the computer connected), you have to first go to start>run>type in cmd and when command prompt opens, type in "ipconfig -all", which lists your IP addresses, etc. Make sure you add the -all (With a space after ipconfig) or else you can get your computers MAC address. The Physical Address is your MAC address. Now once you obtained the MAC, go to your router configuration, and login. Then look for where you can set or clone the MAC address of the router. The default mac address could be on the bottom of the router, if so check for it and just look for that address in your web configuration, then change it to your computers MAC address.
Hope this will fix it!
Feb 28, 2009 | Linksys Wireless-G WRT54G Router
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Setting up the BEFVP41 Router with a Cable Modem and a Dynamic IP Address
Connecting the Router and the Modem 1. Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. 2. Shut down the computer, and unplug the power cables to both the router and the Broadband modem. 3. Disconnect the Ethernet cable from the computer and plug it into the Internet or WAN port of the router. 4. Take the Ethernet cable that came with the router (or any another available cable) and connect it to the computer. Then, take the other end of that same cable and connect it to Port 2 on the back of the router. 5. Plug in the Broadband modem's power cable and wait for all of its lights to stop blinking. 6. After the lights on the Broadband modem stop blinking, plug in the router's power cable. 7. Start up the computer. Obtaining the PC's MAC Address Windows 98SE/ME 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input winipcfg into the ?Open? field, then click on the OK button. 3. The ?IP Configuration? window should appear, select the Ethernet Adapter that the PC is using from the drop down list. 4. Make note of the ?Adapter Address? which is the MAC Address. Windows XP/2000 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input cmd into the ?Open? field, then click on the OK button. 3. When the ?MS DOS Prompt? appears, input ipconfig /all then click on the [Enter] key. 4. Make note of the ?Physical Address? of the Ethernet Adapter (normally ?Local Area Connection?). Accessing the Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Cloning the MAC Address The steps for configuring the MAC Address Cloning feature of a Linksys router vary depending on the firmware version the router is currently using. From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. From the ?Setup? page, click on the MAC Address Clone sub-tab. 2. In the ?MAC Clone? section, set the option to Enable. 3. Click on the Clone Your PC?s MAC button. Once this is done, the ?User Defined Entry? will show MAC Address of the Ethernet Adapter of the computer you are using. Verify this address with the ?Adapter Address? or ?Physical Address? observed in earlier steps. 4. Click on the Save Settings button. Then, click the Continue button if prompted. If the logo matches the image above ("Linksys"), follow these steps: 1. From the ?Setup? page, click on the Advanced tab. 2. When the ?Filters? page loads, click on the MAC Addr. Clone tab. 3. When the ?MAC Address Clone? page loads, enter the the ?Adapter Address? or ?Physical Address? that was observed in earlier steps. 4. Click on the Apply button. Then, click the Continue button if prompted. Power Cycling 1. Shut down the computer. 2. Unplug the router?s power cable. 3. Unplug the Broadband modem?s power cable. 4. Wait for 30 seconds. 5. Plug in the Broadband modem?s power cable and wait for its lights to stop blinking. 6. Plug in the router's power cable once the modem?s lights stop blinking. 7. Finally, start up the computer and test the Internet connection.
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
NetGear CG814M Wireless Cable Modem Gateway Router Logo
442 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
