Question about NetGear CG814M Wireless Cable Modem Gateway Router
No Internet Through the Router - NetGear CG814M Wireless Cable Modem Gateway Router
Waas up.. me a tech and need a help site for touter..where i can get all default gateway of routers
Posted on Feb 27, 2008
    Novelist:
    Scholar:
  • 123 Answers
If changing from a dial-up connection, see warning at bottom. Troubleshooting Steps 1. Connect your computer directly to the modem, without the router. If you cannot access the Internet, contact your ISP. 2. Reconnect the router, modem, and computer as they were before Step 1. Can you log on to the router? If not then: 1. Check that all cables attached to the router and computer are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot light status, as explained in the router manual. 3. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual. 4. Check if the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue this document. If the adapter is not NETGEAR's, contact the manufacturer. 5. Power off the router. 6. Power the router on again. 7. If you still cannot log on to the router, then do a hard reset on the router, as described here: http://www.fixya.com/ThreadView.aspx?thid=102071&prdid=252225. 8. If you still cannot log on to the router, Contact NETGEAR: http://kbserver.netgear.com/kb_web_files/n100005.asp . 3. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 7.) 4. If a dynamic IP address is discovered, go to Step 8. 5. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 8. 6. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 8. 7. If the Smart Wizard does not find an IP address: 1. Power off the router. 2. Power off the modem. 3. Power on the modem. 4. Power on the router. 5. Go back to Step 3. 8. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access! 9. If the page does not display in a minute, check here: http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102076 . 10. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the modem, router, and computer, in that order ? waiting for each to completely reboot before rebooting the next. 11. If the modem's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are not greyed out, then settings for a dial-up connection are being used. Warning: If you are a dial-up user converting to a cable or DSL connection, some software will not work when both types of configuration are present. Configuring your new connection may stop your dial-up connection from working. You may have to configure to connect one way or the other.
Posted on Feb 19, 2006
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Wont connect to internet
Yes you hve to setup the router again, the wireless setting especially.
Turn mac control off in wireless security and let me know how you get on.
Jan 21, 2010 | Linksys Wireless-G WRT54G Router
The network is working but I can't get the internet
If the internet is not working first thing to check here is the internet connection from your modem without the router, make sure that your computer can access the internet when computer is connected directly to modem, if no internet without the router you need to contact your ISP for that, but if there's internet without the router you need to reset and reconfigure the router.....if you have the setup CD of the router just run that to reconfigure it back.........
Aug 12, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Belkin router not working
Are there no leds when you power up the router? If there are no leds make sure the 110 volt circuit the router is plugged into is not tripped. If you have leds try holding in the reset button on the back of the router with a paperclip the botton is a small hole located by the internet/wlan port, hold for 10-15 seconds this resets the router to factory defaults. BPCS
Dec 28, 2007 | Computers & Internet
NetGear CG814M Wireless Cable Modem Gateway Router Logo
173 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
