Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
Blown fuse I looked inside the set, but did not see a fuse. Would you happen to know where the fuse would be located? I looked at the location of the power cord connection but did not see one there. Thank you much!!
    Problem Solver:
  • 25 Answers
Hi,you can locate the fuse near the power supply section,if there is power cord connection i think it is battery operated then check the battery.
hope it may help,
regards
Posted on Sep 10, 2008
Rear wiper fuse is blown again on 2013 mkx
Blown fuses will look dark and smokey, also there should be a map of the fuse locations on inside of fuse door, or just go to Oreilys and ask them...
Jan 09, 2014 | Lincoln MKX Cars & Trucks
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
Blinkers not blinking or lighting up
will try to help. sounds like you've blown a blinker fuse,you'll need to look for fuse box.you did'nt specify make and model,but will try to point you to its where abouts. look under dash on drivers side next to the door. if you have an owners manual for car,look there for location of fuse box and it should tell you where the fuse location is inside the fuse box.simply replace the blown fuse and check for a blown turn signal bulb also.thank you for choosing fixya.com
Nov 29, 2010 | Dodge Ram 2500 Cars & Trucks
My windshield wipers fluid motor stoppped working,is there a fuse I need to replace.I have a 2007 ford edge
Hi the chances are its not a fuse thats gone its more likely going to be that the motor has seized this happens if it hasnt been used for a while.
If you look inside the fuse box you should see printed on the inside lid the location of all the fuses and if its not written on the inside of the fuse box then the chances are it is going to be written inside the owners hand book, so look in their and then check the fuse for that part.
If you cant find any fuse location instructions then just look inside the fuse box and replace any fuses that are blown if you find any then if it is a fuse you will find a blown one and then should solve your problem.
So if you find no blown fuse then the chances are its going to be the motor this would need testing to see if you hed power going to it if their is no power going to the motor then this would indicate the switch itself was faulty and would need replacing.
Let me know how you get on or if you need further assistance ok
Jan 03, 2010 | 2007 Ford Edge SEL Plus
My wii blew a fuse and i want to know what to look for
hello the fuse inside is made of glass if you open the wii up you should see the power supply the fuse might have a cover over it, if the fuse is black it's blown, if you put a nother 1 in and blows again the then you have a dead short somewhare make sure the power off. good luck.
shaun
Nov 13, 2009 | Nintendo Wii Console
Door locks and dome light stopped working
Check for a blown fuse(s). Fuse box should be somewhere around the steering wheel.
Oct 10, 2009 | 2004 Dodge Stratus
Blown fuse for inside accessory outlet
Check your owners manual, this should tell you exactly where it is located.
Jul 12, 2009 | 2004 Dodge SRT-4
No Power
all sets must have rated fuse for protection. some units now use what is called a PICO-FUSE.this type of fuse is soldered into the pc board. usually marked with location i.d. F301,F901,F400. etc. these fuses look like resistors or in-line coils. check continuity w/ohm meter. if new fuse blows as soon as you plug in tv, suspect bridge diode ciruit or main filter cap(large ripple filter by main fuse. if new fuse blows when you try to turn on, suspect 130v regulator or high voltage short(horizontal-output, flyback transformer) good luck!
Feb 20, 2009 | Televison & Video
Parking lights out
Check the Fuse Box inside for a Blown Fuse with a Really Good Flashlight. You will be able to see which one is Blown. Then Locate the Fuse Relay Box under the Hood and look at the Diagram inside the Cover and Locate the Illumination Relay, Replace this if you cannot Find a Blown Fuse. Please Rate My Response! Thanks!
Feb 06, 2009 | 2006 Scion xB
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
530 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
