Question about Sansui Televison & Video
Hissing sound inside my sansui tv
I hear hissing sound inside i open it and i think the hissing sound came from the transformer
  • 28 Answers
You have a short on the secondary side of the transformer that is hissing. You are going to need someone knowledgeable in electronics, to help you find the short. Most likely it is your Horizontal output transistor.
Posted on Sep 18, 2008
My tv its showing black fant pictures with sound. When you put it on it spacks in side. What can be the problem of all this? Sansui sv2916.
open the tv and then put it on then look carefully where the spack is, if it is from the line transformer then replace it with thesame number if u can but if u can not take it to a qualifield techni bcuse the voltage is very high
Jun 03, 2015 | Sansui Televison & Video
Hear clicking noise inside the tv and also no picture
If the noise is louder like sparking than shut off the set as there is leakage from EHT (extra high tension transformer) which can be replaced by technical expert,if the sound is not louder than there is failure of internal power supply that can be repaired by technical expert.
Jan 21, 2011 | Sansui 32" TV
Turn on tv screen is blank hear clickling noise
If the noise is louder appears as if sparking inside the set than turn off set as there may be leakage in the EHT (extra high tension transformer) which can be replaced by some technical expert,if the noise is not louder than there is failure of internal power supply,get it repaired by technical expert.
Jan 21, 2011 | Sansui D 27" TV275 TV
I have one LG 21" color tv ( MACH 4 model) and it is not getting start.It was working properly with some hissing sound but yesterday it didn't started, the LED at the front panel is glowing but TV is not...
Hissing sound comes from leak EHT transformer but front LED working means your power supply is ok so you need to check horizontal out out Transister and series resitor feeding to voltage from B+ to that transistor if it's gone pls replace the EHT transformer as well
in srilanka EHT is around $5 and transistor is $1
thanks
Aug 27, 2010 | LG Televison & Video
My SONY KV-XF21M80 produce a hissing (sparking) sound
That model number is not correct. What is an EHT? Must mean HVT High voltage transformer. If this set is 26 inch or smaller replace it. If larger yes replace the transformer.
Nov 23, 2009 | Televison & Video
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Sylvania wont come on
pls check the power supply ckt. the sound might come from the transformer of the power supply ckt. switching regulator maybe is not pulsating.
Feb 21, 2008 | Sharp 27H-S60 TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
Televison & Video Logo
130 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
