Question about Microsoft MN-700 Wireless Router
VPN how do I make my router work with VPN?
    Novelist:
    Scholar:
  • 123 Answers
The following is from a nice guide i found on the net, see if it works for you: First thing to check is whether your router has any settings for PPTP or IPsec "pass through". These are commonly found in Linksys routers but you may have to hunt around for them on other makes. All you need to do is enable the setting for the VPN protocol that you're using, reboot your router and, if you're lucky, the VPN connection will come right up. Note: Not all routers have these enables and the lack of them doesn't necessarily mean that you can't get VPN working. Open up that Firewall Still no connection? The next step is to try opening some ports in your router's firewall to get your VPN connection made. In each case, you'll need to open the specific ports (and protocol) to the IP address of the computer that you're running the VPN client on. NOTE that port mappings work with only one computer at a time. If you have multiple VPN clients that you need to connect, your router will have to support the VPN protocol that you're using without requiring ports opened. If you're using Microsoft's PPTP protocol, TCP port 1723 is the port you'll need to forward to allow PPTP control traffic to pass. Figure 2 shows the Forwarding screen on a Linksys BEFSR41 set to forward this port to a client with IP address 192.168.5.100. PPTP also needs IP protocol 47 (Generic Routing Encapsulation) for the VPN data traffic itself, but note that this is a required protocol, not a port. The ability to handle this protocol must be built into the router's NAT "engine"?which is true of most present-generation routers. IPsec-based VPN's need UDP port 500 opened for ISAKMP key negotiations, IP protocol 51 for Authentication Header traffic (not always used), and IP protocol 50 for the "encapsulated data itself. Again, the only "forwardable" item here is UDP port 500, which is also shown programmed in Figure 2 to the same LAN client machine?protocols 50 and 51 must be built into your router. Tip: Not all routers are created equal! Some allow only one VPN tunnel to be opened and used by a single client. Others support multiple tunnels, but with one client per tunnel. Unfortunately, most vendors don't make the VPN pass through capabilities of their products clear in their documentation, nor do they have support staff properly trained to provide this information either. In most cases, your only option is to try a router in your specific application, and make sure you can return it and get your money back if you can't get it working. Still not Working? Getting many IPsec-based VPN setups working can be a black art due to the wide variation in techniques used by various vendors. Although IPsec products have become more uniform as the technology matures, your company may use older, more proprietary products that may not be configured with NAT in mind, or require additional ports to be opened in your firewall.
Posted on Feb 19, 2006
Purchased a new D-link router, Cannot open my VPN for my work through the router, what is the problem. My VPN wored before my modem was connected to the router, what can I do?
Not all routers will pass all types of VPN successfully. My last D-Link router would pass a PPTP VPN with no problem, but completely choked on any attempt to pass an IPSEC VPN.
Since you never specified what model router you have, it's difficult to diagnose your problem beyond that observation.
Try a different brand or model of router and see if you get better results. Sad to say, I have found that the low-end routers work fine with completely vanilla networks, but they are very prone to annoying surprises like this when you try anything beyond what the average home user would try.
Oct 31, 2010 | D-Link Computers & Internet
WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Jan 12, 2010 | Linksys WRT120N Router
Edimax BR-6574n wifi VPN connection problem
I have reseted the router configuration back to Factory Default, and set it up again from the beginning. I think the problem was at the firewall settings.
Aug 24, 2009 | Edimax PRI-682 Router (PRI682)
Router settings to allow MacPro to access corporate VPN through router
The university that I attend compiled a great guide for setting up their VPN off campus. These should work for you as well:
http://www.it.ubc.ca/security/VPN/setupdocs.html
So far as I can tell, you shouldn't have to change the settings on your router to access a VPN from your home.
Aug 14, 2009 | Linksys RVS4000 Router
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Vpn client
This router has built is VPN software that allows VPN from anywhere in the world. There would be no need for a software based VPN
Jan 15, 2009 | D-Link DI-804HV - 4-Port Broadband VPN...
VPN connection issues
check if you can enable "VPN pass-through" on your home router.
try diabling its security features (firewall) one at a time and try afterwards.
last option perhaps try upgrading to the 5.06 version of the vpn client.
Apr 06, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Trying to get VPN to work but not sure what fields to fill out to open ports on router. There is a previous post about opening some ports but I'm not sure what to fill out in all the fields or what it is...
you should at least provide with the router name and modem number , than i can provide you with the port number and how to open the port or more specifically "PORT FORWARDING" FOR YOUR vpn connections ... thank u
May 16, 2007 | SMC Barricade 7004 Router
Open Questions:
See all Microsoft MN-700 Wireless Router Questions
Microsoft MN-700 Wireless Router Logo
815 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
