Question about Canon Cameras
Need to know the polarity of the dc3.5v input on sx100is please.
    President:
  • 1,114 Answers
Hi - Check the following web site for an equivalent charger:
http://www.batterygenie.com/ac-adapters-5/digital-camera-camcorder-39/canon-adapters-41/ack-800-ca-ps800-equivalent-ac-adapter-147.html
If you enlarge the picture you can just make out it's center positive:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 08, 2008
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
I have a jkexer polar 5090 treadmill and its coming up E1 any ideas please
1) You must adjut the speed sensor, clean it, tight the connector very well.
see the diagram attached.
2) Lube the deck belk, you have deck belt worn.
3) Lube the rollers bearings.
4) Test the input voltage for motor, if there are the motor need repair.
5) Test the output board, for input voltage motor, if there are not the board is faulty.
Sincerely. God bless you,
May 10, 2012 | Polar Exercise & Fitness
Hi, I'm not sure of the polarity of the Lexicon mx200. I have bought a multi tip transformer & it gives 2 options of outside + or inside +, do you know which is which please, I don't want to fry it!...
DO NOT use universal adapters to run these devices. Accidents are too easy and often the universal devices do no have adequate filtering. You are off on the wrong foot to start with as this unit does NOT have a polarity since it REQUIRES an AC adpter, not a DC one. What you have WILL NOT WORK. If you have connected it, it should NOT have caused damage, you just won't get any audio out, even if the unit lights up on one polarity. The unit generates both polarities inside using the AC input.
Here is an example of correct adapter: http://lcdpayless.com/productpage.php?productId=5793
Apr 25, 2011 | Lexicon MX200 effects unit (with )
What is greatest dpi for PowerShot SX100IS?
Yes your camera will give images with 300dpi . You need to set the dimension as 3264 x 2448.
Hope this helps.
Jan 30, 2010 | Canon Cameras
Blows 15 amp car fuse as soon as switch is turned on nothing plugged into inverter
If the fuse doesn't blow until you turn the inverter on, the problem is in the input circuit. First, be sure the polarity is correct when you're connecting the inverter. If you manage to get the 12 volts hooked up backwards this will blow the fuse. If the input polarity is correct, the diode inside that protects against reverse polarity may be shorted. Beyond that, it's difficult to make any suggestions about what parts to check. You would need to use an ohmmeter to check the parts in the input for very low readings from the 12 volt input to ground. If you can do this yourself or know someone who can, it might be worth a try. But if you try to take this somewhere for service - if you can find a shop willing to look at it - it may be more economical just to replace it.
Good luck with the inverter, and thanks for using Fixya!
Nov 24, 2009 | Powerline 0900-73 Slimline Inverter
Need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Sep 25, 2009 | Kitchen Appliances - Others
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Voltage/polarity of power supply for NEC pcmcia 4 port USB2 card
If you KNOW it is 5 volts then you only need to make sure that the amp is higher and never lower. Higher amp only means it can work without getting too hot. But the VOLTS MUST BE precise. For polarity it is MOST common to have the center pin PLUS and outer NEG/GND. When I fix laptops and put the powercord wrong nothing happens. When I get it right then lights go on on PC.
Oct 31, 2017 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
I recently brought a canon SX100IS digital camera. We are slowly reading the book and working out the functions. On taking a snap the other night a hand appeared in the right hand side of the screen, what...
Hi - You can download the manual from the link underlined in blue below:
SX100IS
See page 73, you have the image stabilizer set:
Informatica
Aug 16, 2008 | Cameras
Cameras Logo
126 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
