Question about Microsoft MN-700 Wireless Router
Networking xp and 98
How do i use the MN-700 to link PC's using XP and win 98?
    Novelist:
    Scholar:
  • 123 Answers
First off, the MN700 basestation is not suported to do this. But it is doable, and here is what I did. I connected a win XP machine (the ICS host) to a win 98 machine (the ICS client). Both used good old fashion network interface cards and standard ethernet cable - no wireless for me yet (that's next week) First I installed the software for the MN700 - aka the "Microsoft Broadband Network Utility." Then I went in to configure the router. I simply set the MN700 to Access Point mode. I did this by logging into the MN700's Base Station Managment Tool. I gave the MN700 a name (ie MSHOME-MN-700 works well), because after I change it from Router to Access Point mode it will no longer have a fixed IP address. To change it, select Security -> Base Station Mode Select the radio button for "Access Point" There is a spot on the bottom of this screen to give the Base Station a name, put something in here (ie MSHOME-MN-700). click apply. Now, I restarted my winXP machine, my win98 machine, and my MN700. Once they all came back online, I went to my dialup connection (Start->Control Panel then select Network Connections). Right click on the dialup connection, and go to properties. On the advanced tab, select the check box for "Allow other network users to connect through this computer's Internet connection." Click OK Now I restarted my winXP machine and the MN700 again. They came back online, and I could see the MN700 on the network (my machine now gave out IP address (via DHCP and ICS). Now I restarted the win98 machine and it hooked up to the network fine. Wireless devices also connect to the network now with no problems. The key is to set the MN700 from Router to Access Point. If you want to add File and Print Sharing, it is the same as on any network. If you have a USB highspeed modem, this will work as well. If you have a highspeed modem connected directly to a PC via ethernet and you don't want it to go throught the MN700 first, this will work too, but the PC will need a second ethernet interface. Either WiFi or wired. Cheers
Posted on Feb 19, 2006
Win 98 recovery used instead of win xp sp2. computer won't start, shows win 98 screen and stops
win XP will not use anything from a win98 program. If XP is installed you must either use the recovery discs or better, the original XP disc.
Sep 22, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
How to configure network in windows 98& xp
Windows 98 isn't networkable, it needs to be upgraded to at least Win 2000. Also if it's XP Home addition that isn't networkable, it needs to be XP Pro.
Jan 02, 2010 | Microsoft Windows 98 for PC
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Problems adding a vista computer to a mn-700 network
you need to install a driver in your vista which will enable you to print your files.i hope this helps
Dec 29, 2008 | Microsoft MN-700 Wireless Router
Partition not 100% on laptop 700 presario
From the description loo\ks like it's not a partition problem, but the Compaq CD.
Try to partition Hard Drive using Windows 98 bootable CD.
Try to install Win XP from different CD - doesn't have to be Compaq. Later you can download drivers.
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
NT4 sees XP Pro in network neighborhood, but access denied
If you arent too worried about security since it is at home, enable the guest account on the windows XP machine, also disable the firewall on the XP machine ( it is on by default )
let me know
Oct 29, 2008 | IBM NetVista PC Desktop
Hav u got driver for c785 for xp
Dear Rahul,
Sorry for that, the mic is not working in windows xp operating system it is ture i ask the HP person he say that this laptop hardware not design for win xp OS. so plz install the Vista OS to use the full feature of the laptop buz in win xp the sound driver install force fully. it is not install the full sound driver. if it is possible any link in future i mailed you link.
bye
Jul 30, 2008 | Compaq Presario 700 470024-192 Notebook
I want to download compaq presario c773tu drivers for winxp prof. Could you please update where can I download the drivers?
USE THIS LINK AND YOU SURELY GET DRIVERS FOR ALL WINDOWS XP VERSION DRIVERS FOR C773TU. I AM TESTED ON MY COMPAQ PRESARIO LAPTOP WORKING SUCCESFULLY.
DOWNLOAD IN CORRECT ORDER.
http://saysprasad.wordpress.com/2008/08/08/compaq-presario-c773tu-laptop-drivers-for-windows-xp/
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Open Questions:
See all Microsoft MN-700 Wireless Router Questions
Microsoft MN-700 Wireless Router Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
