Question about Microsoft MN-700 Wireless Router
Wireless hub Do I need to have the broadband software installed to access the router admin? I have a D-Link and I just type in the address and it brings up the admin interface on the router. I also noticed that it always ties to connect to the net automatically. I'm just using it as a hub and wireless access point on my pc to share my dial-up net access with my other pc's. I'm running xp sp2. Thanks
    Novelist:
    Scholar:
  • 123 Answers
No, you do not have to have the broadband software installed. To access the MS base station go to : http://192.168.2.1/login.htm Using it as a hub and access point requires you to configure is as such. The MN700 can act as a hub/wireless access point using an ethernet cable from your router to the modem port on the base station. The base station has to be setup with the ethernet cable in port 1 on the base station connected to your PC. see "Reconfigure the MN-500 as a Wireless Bridge" in this article. same steps apply for your MN700 http://www.fixya.com/ThreadView.aspx?thid=102065&prdid=254958 The last step is to reconnect the ethernet cable from the router to the modem port on the MN700.
Posted on Feb 19, 2006
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
I HAVE A LINKSYS wireless-B broadband router 2.4 Ghz 802.11 Model BEFW11S4, and i am on guest account and i do not have a disk for instilation so is there a way to instal it without a disk?
You dont need an admin account or installation disk to install the Linksys router that you have.
Just get an Ethernet Cable plugged in to 1 of the 4 ports at the back of your router and plug it to your computer.
Then Access your router via your computer by opening Internet Explorer and type 192.168.1.1 to the address bar.
if it would ask you for Username and Password, default should be the one below.
Username:
Password: Admin
As you can see you just need leave the password blank and put admin to the passowrd.
if this password doesnt work just press the reset button at the back of the router for ten seconds and restart the router.
After that try accesing the router again. It should now let you access your routers setup page.
Oct 05, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
How to change linksys wireless-G broadband router password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP security change the password and save settings.Then restart router then you can connect wifi with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | Linksys Wireless-G Broadband Router
Wireless zero configuration
First make sure that wireless network adpter driver installed and enable.
You can check it in device manager.
Then ake sure that wireless is enable in router.
For that access your router with below method.
http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings and enable it .
Also set channel type as 3 or 6 or 11 enable broadcast.Then saves ettings and restart router then check.
Thanks for using FixYa..
Jul 20, 2010 | Acer (91.AD303.001)
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
Can't find security code for router
Security default is admin for username and admin for password.
You can access your router by typing 192.168.1.1 or similar in your internet address bar to access router's programming
Sep 02, 2009 | Linksys Wireless-G Broadband Router
How do i install my zonet wireless broadband model # ZSR1134WE
after it is connected, connect computer to router via ethernet cable, then when you find the address bar online, type 192.168.1.1 to access the new unit.. If it asks for username and password which it shouldn't it would be "admin" for both
Jul 07, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
My laptop doesn't recognize ip address on wireless router, EnGenius ESR-1220. Everything else on my pc seems fine.
Do you want to ge access to your router?
type this: http://192.168.01 or http://192.168.1.1
Router Address Username Password 3Com
http://192.168.1.1
admin
admin
D-Link
http://192.168.0.1
admin
ts.gif Linksys
http://192.168.1.1
admin
admin
Microsoft Broadband
http://192.168.2.1
admin
admin
Netgear
http://192.168.0.1
admin
password
Oct 06, 2008 | Computers & Internet
Open Questions:
See all Microsoft MN-700 Wireless Router Questions
Microsoft MN-700 Wireless Router Logo
261 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
