Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanning i am trying to scan an original on my hp officjet 6110 all-in-one and cannot get it to work.help please
  • tripwire45 May 11, 2010
    Can you be more specific? What are you trying to do to get it to scan? Are you pressing the scan button on the machine or are you using the Scanners and Cameras in the Control Panel section of your Windows computer?
    I have a 6110 myself and have never been successful at getting it to scan by directly pressing the scan button on the printer. I use the option available though Windows and get it to scan just fine.
    HP.com has a web page that gives an overview of how to scan that might help you:
    Scanning Overview
    Hope this helps. If not, please post back more detailed information about what you are doing to try and scan. Thanks.
    New Friend:
  • 109 Answers
When you scan file/s use the scan program not scan button and has feature what you will scan before it goes on processing.
Posted on Oct 17, 2008
How do I scan a picture and email it?
Hi
You can start a scan from your computer or from your HP OfficeJet.
to scan an original from your Windows computer
1 Load your original either on the glass or in the automatic document feeder
(ADF).
2 Press Start Scan.
A scan of the original appears in the HP Preview window.
3 In the HP Preview, you can edit the scanned image. When you have
finished, click Accept.
For more information about making changes to an image during the
preview, see adjust an image during the preview in scan pictures and
documents in the HP Photo & Imaging Help for more information.
The HP OfficeJet does a final scan of the original and sends the image to
the HP Photo & Imaging Gallery.
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Originally my hp officejet 6110 had a scan error, cannot connect to pc. Then I did a #6 reset and now says no scan options, you need to install or run HP software for feature. I updated the drivers but...
>> open solution center,
>> go to tools
>> click on scan settings
>> click on scan to.. set up.
>> there must me some options in LHS block.
>> which u have to move to RHS block.
>> then click on update device below.
>> restart your PC n printer
>> n have fun..!!
Dec 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Does anyone know if Windows 7 fixes the problem that Vista users have with HP Officejet 6110 scan function? ie: not respondind to buttons on 6110 when trying to scan.
yes it will fix the issue :
Need to download the driver for Windows 7 from the hp's website.
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79477&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
Also try to print
Also try to scan from the scan button on the printer
This should resolve your Issue
Oct 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Black page printwhen I try to copy or fax from my hp 6110 printer
The printer isn't shot, but the scan assembly is, it sounds like either the scan lamp is dead or the sensors in the scan assy. You should also be getting a scanner error. I would try the reset, powering up with either the #3 or #6 buttons pushed, and see if a reset helps.
Jun 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 xi All-In-One will not scan
This is an interesting problem because a printer isn't "intelligent" the way a computer is "intelligent". While devices such as the 6110 have RAM and thus "memory", they don't have the ability to recognize which devices are connected to it, as such. That's why you have to install all of the HP software and drivers onto the Windows or Mac machines, so the burden of recognition and interfacing is on them.
That said, information and even errors can be stored in a printer as long as it's receiving power...sometimes even when they're turned off.
My first suggestion is to completely turn off the 6110 and unplug it both from it's supply of power and from any computers.
Let it set for around 30 seconds to a minute so that any residual power from the "brick" dissipates.
Reboot the Windows computer.
Then plug the 6110 back into it's power supply and attach it back to the Windows computer.
Power up the 6110 and let it go through it's start up and alignment routine.
Try to scan again as you originally did before you tried to us your Macbook with the 6110. Hopefully that will do it.
If, for some reason, the Windows machine is still not able to interface with the 6110, you may have to completely uninstall all of the HP software and drivers from the laptop and reinstall them using the original installation CD, just as if you were installing the printer with the laptop for the first time.
This means (assuming you have Windows XP), going to Start -> Control Panel -> Add or Remove Programs. You'll need to go through the list after "Add or Remove Programs" opens to select and uninstall all the software and drivers that have anything to do with the 6110. Hopefully, this'll be just one or two selections.
If you have the original CD, you can also insert it and it should offer you the option to uninstall the original software and drivers. That would be the easiest. Then you could just turn around and do a reinstall from the disc, no muss, no fuss.
If you do not have the original CD (and believe me, these things get lost all the time), you can still download all the latest software for the 6110 onto the Windows laptop by going to this web page at HP.com:
Officejet 6110 Software and Drivers
Once you go to that page, you'll need to select your particular Windows operating system name. You'll be taken to the web page where you can download the installation software and the latest drivers. Once they're reinstalled onto your system, you should be good to go.
You "may" be able to install the latest software and drivers without uninstallng the old stuff first (that is, you could be offered the option to overwrite the old software when you install the newer software),. but that's not as "clean" and instead of curing the problem, it could make it worse. If you're a risk taker, go for it. If not, don't take the chance of more headaches.
I probably made this sound more complicated than it is. Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning?
hi
if u have proper installed scanner u see your scanner in my computer .
so u got scsner and camera wizard in my computer.then u opoen it and then folow the procedure.
Sep 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scan Problem with HP Officejet 6110 All-in-one
Once try to scan from the scanners and camera wizard to check the two way communication between the computer and the all-in-one.
  1. Verify that the all-in-one product power is turned on and the printer cable is properly connected.
  2. Click Start .
  3. Click Programs .
  4. Click Accessories .
  5. Click Imaging .
  6. From the Imaging application, click File , and then click Select Device .
  7. Select the HP all-in-one device from the TWAIN source list.
  8. Click File , and then Acquire Image . Imaging for Windows will scan from the all-in-one product using TWAIN software instead of the HP software.
If you are able to scan by performing the above steps then search for the file hpqscnvw.exe and try to scan from there.
If you are not able to scan even from the above steps, once refresh the USB cable and then try to scan again.
if you are able to scan from that file then try to scan from HP Director, if the issue persists then create a shortcut icon for that file and then try to scan else uninstall the software and reinstall.
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
