Question about Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router
Wireless Bridge how do i Reconfigure the MN-500 as a wireless bridge?
  • 513 Answers
Do this to change from routing mode to bridging mode, which allows your MN-500 to act as a wireless access point. Important: If you follow the procedures I've listed below instead of the procedures documented in the MN-500 User Guide, you will not lose the ability to administer the MN-500. This will give you the ability to change the SSID, channel, and encryption key if needed without performing a factory reset of the base station and starting from scratch. 1. While logged into the BSMT, click the Local Area Network link and access the Settings page. 2. Change the IP address from the default (192.168.2.1) to another IP in the same range and set the DHCP server to disabled using the list. Click Apply. In the example shown above, I've changed the IP to 192.168.2.252. Wait for all lights to turn green on the base station. 3. Open the BSMT again using the new IP. Use your Web browser and navigate to http://192.168.2.252 and enter your password if prompted. You will not be able to open the BSMT from the Microsoft Broadband Networking Utility (BNU). 4. Click Security, and then click Network Mode. 5. Click Bridging mode, and then click Apply. 6. Disconnect your computer from the MN-500 but do not disconnect the power from the MN-500 because it may take several minutes for the hardware to restart in access point (bridging) mode.
Posted on Feb 19, 2006
Wireless bridge set up
Login to the bridge to configure connection to the router.
Jan 14, 2014 | Linksys WET610N WirelessN Bridge...
When using my laptop i have to reset my wireless
A Problem with the firmware ;Hard Reset and reconfigure
Mar 27, 2010 | Microsoft Broadband Networking MN-500...
How to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
Linksys wireles G enternet wet54g
The settings on that bridge(the far away one) might have been reset somehow. Try to reconfigure it, you can contact the manufacturer to help you set it up
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Using a wireless bridge for Dreambox
i dont think it has wirless on it mate but j tag it
Apr 16, 2008 | Trendware TEW-430APB 802.11g/b (TEW430APB)...
WGR614v6 - Bridge mode
This may provide some input for your request.
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=23547&action_code=5&highlight_info=16777285,88,115&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=18710634#__highlight
Dec 11, 2007 | NetGear WGR614 Wireless Router
Slow Internet
upgraded the latest firmware in the router, reset your router and reconfigure it, check if your dsl modem is configured in a bridge mode if not configure your modem in bridge mode and reconfig your links router accordingly, that will fix your problem
Nov 26, 2007 | Computers & Internet
Wireless hub
No, you do not have to have the broadband software installed. To access the MS base station go to : http://192.168.2.1/login.htm Using it as a hub and access point requires you to configure is as such. The MN700 can act as a hub/wireless access point using an ethernet cable from your router to the modem port on the base station. The base station has to be setup with the ethernet cable in port 1 on the base station connected to your PC. see "Reconfigure the MN-500 as a Wireless Bridge" in this article. same steps apply for your MN700 http://www.fixya.com/ThreadView.aspx?thid=102065&prdid=254958 The last step is to reconnect the ethernet cable from the router to the modem port on the MN700.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router Logo
646 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
