Question about Dacor MCS130 Millennia Electric Single Oven
Dacor oven beeping
Keeps flashing error codes F1 and F5 not in manuel My Dacor convection oven began beeping and then the F1 code came on.  All the press keys are dead except the one that cancels.  When I push that the beep stops for @30 sec and then comes back on.  The only way to stop it is to throw my circuit breaker for the oven.
I tried  doing that and left it off for 15 minutes, hoping it would reset.  No luck.  Some of the comments I've read suggest there is a reset button on the back?
I called Dacor and they said it could be the panel, the wiring or one other thing.
  • Anonymous Dec 18, 2008
    Same problem. Apparently, if you leave the door to the over open too long it can melt the circuitry in the panel, causing a short that will result in the beeping. New panel will fix it.
  • Donna Abbott Jul 30, 2013
    My stove beeps at random times. Stove & oven are all functioning but the beeping noise will drive you crazy. If I turn on oven and press temp up, beeping may stop for a short time or may stop for a few days but it always at some point starts beeping again. I have resorted to shutting breaker and using lighter for stove top. When I call repair they say I may need a new mother board which I replaced a couple years ago at a cost of over $700. Please can anyone help me, just want to know how to turn off beeper???
SOURCE: dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Posted on Sep 05, 2007
reg501
  • 413 Answers
SOURCE: F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Posted on Jul 02, 2008
SOURCE: dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Posted on Oct 26, 2008
vitg55
  • 78 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
F1 error Dacor Oven
Regards;
reg501
Jun 29, 2008 | Ovens
Dacor oven beeping
Apr 25, 2008 | Ovens
Dacor error codes
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Dec 04, 2007 | Ovens
Dacor MCS130 Millennia Electric Single Oven Logo
517 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
