Question about Garland PS-36G-4-26 Gas Kitchen Range
Garland range griddle top
I have a garland 6 burner gas range with 36" griddle top and two ovens. The griddle top seems to be collecting grease and rising at the front, away from the drain. I got the griddle to lift up in the front to scrape the grease away. How do I get it to return to its original setting so the grease will all drain forward?
I have a 48" Garland griddle 4 burner thermostat controlled and I can't have it above low all the way across because it is so hot it burns my eggs. I have 1/4 of the griddle I can cook an egg on, if I turn the griddle where it should be at 250,300,300,350 the whole griddle turns black. I need a repair man to turn down the temperatures that it is set on. please sent a reply to janmid_86@hotmail.com with all the repair companies that are available in around Orillia/Barrie Ontario Canada Thank you
Posted on Jun 04, 2009
    Novelist:
  • 125 Answers
Hi, you may have to remove the griddle top completely, as when you lifted the front, you may have knocked shims out of the back ledge, the best way to do this is get another person to help you lift it off, get the shims back in place, and relevel the griddle.
Hope this helps, and thank you.
Posted on Jan 05, 2009
  • 41 Answers
Make sure your unit is leval if you have alarge build up you will have to remove griddle and claen then reinstall
Posted on Dec 11, 2008
4 Suggested Answers
  • 68 Answers
SOURCE: garland range
The unit does not have it's own shut-off. You'll need to shut it off at the building's supply. The plumber surely installed a valve right behind the unit.
Make sure a technician inspects the gas supply tubing for the OVEN pilots. They run from the front manifold, to the back of the oven, down the back, and under a shield. They tend to go bad.
Posted on May 30, 2008
  • 125 Answers
SOURCE: Griddle top for older Garland 283 gas range
Hi, it may not, depending on the age difference of the units, the grease catch, etc.. contact Garland at www.garland-group.com , or call 1800 424 2411, the parts department should be able to tell you at least. Hope that helps, and thank you.
Posted on Jan 04, 2009
vetteman3002
  • 2299 Answers
SOURCE: We have a Garland commercial
You can clean the parts all with regular dish soap. The oven you can use Easy-Off oven cleaner. And the stainless parts you can get stainless steel cleaner at any grocery store.
Posted on Sep 22, 2010
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Parts manual
Hi, you can call Garland Range at 1.800.424.2411, and talk to the parts department, or you can visit www.garland-group.com and in the top right corner is a "contacts" tab, and you can email them your request. Hope that helps.
Jun 02, 2008 | Garland H286 Gas Kitchen Range
Garland range
May 30, 2008 | Garland H283 Gas Kitchen Range
Mar 10, 2008 | Garland H283 Gas Kitchen Range
Garland PS-36G-4-26 Gas Kitchen Range Logo
709 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
