Question about Philips Magnavox 51MP392H Rear Projection Television
Turns on but no picture
Have the problem that the set will not start up, but I hear the relay click on. I have taken off the back. I can see the middle picture tube arching in the neck. The other two are glowing. Bad tube? I want to know what I am getting into.
Thanks
Jason
    Genius:
  • 1,139 Answers
It appears that one of the CRTs has a short in it. It can be repaired with a CRT tester or with a capacitor charged up and applied to the grid and cathode pins of the CRT having the problem.
I would advise that you have a qualified TV repair Technician do this.
Thank you,
Shuttle83
Posted on Sep 14, 2008
Hard time to start but when it turns on I hear the fuel pump relay clicking a lot and the idol start going up and down until the car turns off and by the way I got the track light on and the check engine...
Year make and model ?
Have you swapped the fuel pump relay with another ?
Its normal for the traction control light to come on if the check engine light is also on.
Have you checked the engine computer for trouble codes ?
Mar 27, 2015 | Cars & Trucks
Samaung flat screen powers on the off
ok, when you say it turns off, does the entire set shut off or just the picture? Do you hear the relay click when the set shuts off?
Apr 06, 2013 | Samsung Televison & Video
Picture is black. sound went out a few weeks ago and now all that seems to work is the red power lamp turns on and I hear a click but that's all. I am not concerned about the picture since it is c
The click is a power relay on the main board and if the red light is on I would suggest looking inside to see if it has more than one relay--follow the power cord into the set----some of these sets have one relay but others have up to 3.
They are know for sticking open or shut. A tap on them can free them..A look inside even by a novice may also reveal something burnt or unplugged etc.
12_5_2012_3_12_13_pm.jpgview of relay bottom side is up.
Dec 05, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi Model 50DX20B No Sound or picture
GOOD question and well asked----Start at the beginning.
if light on main fuse is good---do you hear the power relay click on and off?
These sets for trouble shooting use a number of green and one red LED inside on the board--the red one should be on when power is connected and the others at turn on all should light--if do this with back off look for the Green ones---when set turned on do all light and then go out--look for one that goes out first or last---each is connected to a specific voltage coming out of the power supply---they will lead you to the area where the trouble is---this set is old enough you may be able to find a service manual online.
I have fixed a lot--going to need a volt/ohm meter for any real tests.
I am ready to help if you need it.
Apr 22, 2012 | Hitachi 50DX20B 50" Rear Projection...
When I turn on this TV, the picture doesn't come on. I can hear the sound, but get no picture. Out of the grill on the back, I can hear a clicking sound like a CD that is spinning and won't "catch." I...
You are hearing the main POWER relay turning on and off, it can be caused by short circuits so it turns off then turns itself back on, or the power supply DC is not steady due to bad caps, it will have to be troubleshoot down to component level, most repair shop will try out a spare power supply module.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LC2D+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | LG 42LC2D 42 in. LCD HDTV
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
98 Accord won't start
Check the main relay-PGM-FI Main Relay, called a fuel injector relay(a gray little box with a plug at the end). To make sure it is a bad relay, do this: Turn the key to II, listen for a humming sound from behind you. It is a fuel pump working. You should hear a click under the dash after it. It is a main relay click . If you do not hear a click, you car will not start. If you do hear a click, you car will start.
Fix is to take the relay out, resolder the joints and put it back in. Go on www. MarkLamond.co.uk and http://techauto.awardspace.com both sites will show you how to resolder the main relay and where it is located if it is the PGM-FI Main relay.
Jun 11, 2009 | 1998 Honda Accord
95 olds achieva starter not engaging
The click you hear is the starter relay. Check for continuity thru relay with battery negative cable disconnected and switch in start position. If no continuity, it probably has burned contacts. Sometimes these can be taken apart and contacts filed/sanded cleaned.
May 02, 2009 | 1995 Oldsmobile Achieva
Tv won't turn on
my funai 3216 was working ok it went off today and wont come back on iv changed the fuse in the plug with no luck iv taken the back off the tv what next please help
Jun 22, 2008 | Televison & Video
TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
May 12, 2008 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
