Question about RCA RS2652 Shelf System
No Other Stations
No matter what station I switch the dial to I get the same station over and over again. Like if I turn to 96.3 or 105.7. Instead I'll get I think it was 93. something
    Champion:
  • 277 Answers
Hi 2 options: 1. ur dial is brook, its strap is torn or the knob isnt working 2.your system crystal is bad you can fix only the first 1 try opening the system and see if u can replace the knob or/and its strap good luck
Posted on Feb 26, 2006
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
WMA stream on a constant loop for my favourite radio station
Since other stations worked perfectly, perhaps the other station was streaming a loop.
Otherwise try this: Support Cobra Electronics Corporation
Mar 21, 2017 | Cobra Radio Communications
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
Radio says loc
that means that you toggles the radio just to receive local stations. It squeezes antenna input. Just find the loc button on the radio and toggle it again. in the manual its calles local stations oposite to long distance
the indicator should switch of when you toggle and more radio stations should be available but also to many stations will appear on your radio. For that reason that function is on there
cheers
rene
May 27, 2011 | Computers & Internet
Can you solve the problem of loosing all digital channels overnight on the L19H01UB television. Thanks Trevor.
Every time you shut down it may have arcing that zaps the memory of DTV stations. Just turn it on again might regain the list of stations. If not then scan the stations again in setup menu.
Oct 21, 2010 | Hitachi Televison & Video
How to get from standard TV to Cable TV?
Should use remote to bring up the menu. Go to channel search and it will ask you if for ant or cable. This is where you will select for antenna or cable.
Feb 15, 2009 | Televison & Video
Setting the stations on memory
OK HERE'S WHAT YOU DO
1. USING THE UP AND DOWN TUNING, TUNE IN THE STATION
2. PRESS THE MEM SWITCH (LEFT SIDE OF ROUND SWITCH)
3. PRESS STATION LOCATION
4. PRESS MEM AGAIN ---- THAT'S IT
SUMMARY: TUNE, MEM, SET STATION, MEM
Jan 01, 2008 | GPX RDT4004SP AM/FM Radio
No fm reception
We had trouble switching from AM to FM. We finally solved the problem by pushing the reset button on the back of the unit (any sharp pointed object can be used to engage the reset button). Do this followed by setting the mode to FM and try tuning in your FM stations. Try the procedure several times and it may finally kick in, as was the case with us getting our AM stations
Dec 30, 2007 | GPX HM3817DT Shelf System
RCA RS2652 Shelf System Logo
20 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
