Question about Maytag Washing Machines
Maytag Neptune MAH8700AWW spins slow Quick Spin test genearates code 8E. Can anyone tell me what the problem is? Ken C
  • Anonymous Oct 31, 2008
    Same problem here!
jsrock516
  • 5911 Answers
SOURCE: CLOTHES STUCK IN WASHER!!!!!!
If you open up the dispenser tray on the top of the machine, there should be a red cord. This is the manual release for the door. All you have to do is pull this cord and the door opens. If the cord is missing, you will need to remove the top of the washer to get to the latch. I hope this helps you.
Posted on Jul 16, 2007
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
  • 32 Answers
SOURCE: maytag neptune mah8700aww wont drain, spin or put water in
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
Posted on Sep 29, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
Krazytech
  • 725 Answers
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
MAYTAG NEPTUNE FRT LD WASHER MAH8700AWW,NOT COMPLETELY THE SPINNING/DRAINING CYCLE,LEAVING CLOTHES VERY WET,WE SELECT SPIN CYCLE ALONE FOR EST. 9 MIN., THEN DRY, NEED A FIX - HAVE ONE ?
Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Feb 16, 2011 | Maytag Washing Machines
Maytag Nuptune... when it reaches the spin cycle, it spins, reverses direction spins , then stops. I push the start button and once again it goes through the one spin and reverse and stops again
""when it reaches the spin cycle, it spins, reverses direction spins""
So I understand do you have the washer top raised to view this action? The wash basket rotates one rotation or are you talking about the tumblers?
If you raise the washer lid and rotate the wash basket CCW the Spin direction will it rotate CCW with very little effort?
Any dC or UC error code on fail to Spin?
If you do Spin Only Cycle do you have the same results.
I would enter Service Mode and do the Quick Spin test on page 14 of the Service Manual and see what the results are.
You can get the SM from this forum once you join.
16022808 Maytag Top Load Neptune Washer Service Manual
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Sep 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Jun 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune in spin cycle goes slowly fav6800aww
Hello smithe623
I’m an owner of the machine.
I assume the machine is not displaying and error code to the LED Display?
I would download the Service Manual and go to page 14 and perform the Quick Spin Test in Service Mode.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
The Quick Spin Test will spin the wash basket up thru all RPM ranges starting at 90 RPM .15 =150 RPM, .35 = 350 RPM all the way up to .85 for 850 RPM. Report back on the results of the Quick Spin Test and we will go from there.
You can get out of Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or press the off button on the console.
Take care…..Rich
Nov 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer stops after filling with water on the first cycle...will not spin Neptune stops after filling. No codes. Lid unlocks. Ideas?
Hello n8mtsn,
I would pull the 120VAC power cord to the washer for 10 seconds then power back up.
See if you can get into service mode. To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”. If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test. Follow the instructions to enter the Quick Service Cycle test and let us know the results. If the test will run it will take about 10 minutes.
Link to Service Manual for reference. Sears Parts Direct for reference.
Rich
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
Jul 16, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
