I want to format my sandisk micro cruzer 4gb usb drive to fat but only get fat32 option
  • craig459 Sep 08, 2008
    The usb drive is for use for updating firmware on photocopiers. But they will only work with devices formatted in fat, this device does not give the option and i wondered if it was possible. thanks.
    Cheers!
    New Friend:
Why do you want to format it? If it is file lossing problem, you can try 4Card Recovery.
Posted on Mar 19, 2014
    President:
  • 2,961 Answers
Nobody and nothing uses the FAT system, since windows 98 only FAT32 or NTFS is used, i can't understand why you need FAT?
Posted on Sep 08, 2008
  • andrew pester
    andrew pester Sep 08, 2008
    Shot in the dark, but there may be an option for fat, apologies if you tried this,
    go to my computer icon, right click, then click manage, then disk management; see if drive is listed, click on it then choose format.
Help How can I unblock my sandisk cruzer
Dear Customer, Plz Flow this instruction i think solve you problem.
Reformat the drive:-
  • Right-click the SanDisk flash drive within "Computer" and select "Format..." Enter a name for the drive, select your desired format (FAT32 is typical for flash drives). Click "Start" to format the drive. This, unfortunately, will erase everything on the drive. Any data contained will be lost along with the password protection. Once reformatted, the drive will be fully accessible.
Sep 12, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have 4gb cruza micro. it now says you hv to format before use. please help.
if its brand new you really need to format it. just right click it on my computer then format. choose a file format you want, Fat32 or NTFS then you are done.
hope that helps
Mar 24, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
4GB pen stick cannot write when used space over 2GB
You formatted your pendrive with a FAT32 Filesystem instead of using NTFS.
Do the following. Backup the data currently on the drive, Right click on the drive, choose Format and under Filesystem, choose NTFS ... click ok... you will not be able to use all 4Gb of space on the drive.
Good Luck
Feb 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
What format is the cruzer usb 2.0 flash drive in?
USB Drives are usually formatted as FAT or FAT32 drives
Nov 07, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I need to format the USB I have to a Fat the only options I have are Fat32 NFST and exFat
normally you would format to fat32 that will be compatable with most systems ..... exfat is used only for linux ... but linux can also use fat32 and NTFS .... microsoft can't read exfat without a special program ... you can use NTFS if you hve a very large USB drive ...but fat32 will be compatable with the most systems ...
Apr 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Jan 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Micro 4GB USB plugged it, light on, but shows an empty file in windows with capacity of 0bytes Also shows a CD drive (the one that U3 runs) which says nothing is in disk drive.
It is likely an issue with the filesystem. The FAT filesystem gets easily corrupted. If that's the case, reformatting it with FAT32 should help. But remember - reformatting erases all the data, so don't do it if you have anything important on the drive!
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Problems with SanDisk 4GB Cruzer. looks good at
Okay, Can you tell me the model of your computer?
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
May 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computers & Internet Logo
David Payne
David Payne
