Question about Sharp AR-5316 Advanced Digital Imager Copier
Error code L1
I have tried the 2 solutions posted. Neither one worked. Can you help me?
Jason 404.456.7013 Sharp AR-5316, this machine was shipped from nairobi,kenya  office to juba, sudan to clients. it has never worked at all since arriving here. the display flashes L and 1 and no key accepts any commands.
  • saroj_455 Dec 20, 2008
    Sharp AR-5316, this machine was shipped from nepal shop to multitrading. it has never worked at all since arriving here. the display flashes L and 1 and no key accepts any commands.
  • saleem faeq Dec 30, 2008
    flashes L and 1 and no key naccept aqny command
I have copper machine sharp AR-5316 E it has never worked at all since arriving . the display flashes L and and no key...
and my e-mail is saleemcomputer@yahoo.com
Posted on Dec 30, 2008
EOOOO19-0000
Posted on Sep 08, 2008
Sharp ar 5316 code error L4
This problem relates to the Main Motor Drive on the printer.
The L4 error details that the Motor Drive has been Overloaded.
I would recommend opening the main door and inspecting to see if it's jammed by paper or anything else. Try disconnecting the power and blowing it out with air-cleaner. Then restart and see if the error is still persisten.
There is also another solution that was posted back in '09 by hamzaskilltd, who mentioned that the two common problems can be as follows:
1. Main motor lock detection 2. shifter motor trouble
My second recommendation, if my first doesn't work, would be to either replace the copier or request repair from Sharp or another tech repair shop. Such as Geek Squad which provides industry back support.
Just be prepared that both solutions will cost.
Hope this helps.
Mar 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have sharp AR 5316 im facing #2 or H2 error in my copier please help me and tell me what is this and what is solution for this i am waiting of your reply thank you
On a sharp machine. Press P * C * .... or # * C *. The machine should enter diagnostics mode. then enter 14 then one and press start. That should clear the issue
Oct 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
I Have Sharp AR 5316 when i power on copier L1 00 error pls help me
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 00-The scanner does not complete feeding in the specified time
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code L1
YOU EITHER HAVE THE SCANNER LOCKED OR THE SCANNER RAIL [SILVER BAR UNDER GLASS NEEDS TO BE LUBRICATED.
Dec 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316 E photocopier error clearing
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
Jun 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
206 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
