Question about Acer Aspire™ T180 PC Desktop
Girlfriends computer A telephone tech came in and worked on phone jacks. When he left he somehow managed to stop T180 from having any sound out of speakers. I am unsure of where the speaker jack cable is to be plugged in on this unit to see if this is the problem.
  • rexlove Sep 08, 2008
    That was wonderful Sandrew and thanks for getting back to me so very quick. My lady will be so impressed to have her sound working again on her computer.
    Thank you very much again
    M
    President:
  • 2,961 Answers
The phone jack should be on a seperate card, but the speaker jack goes into the Green connector at the rear of the tower
Posted on Sep 08, 2008
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Where can i locate my dma controller on a acer t180
if its device manager your looking for clik start then right clik on computer or my computer and select manage on menu then ok on next screen then on the next window device manager is on the left of that window
Sep 24, 2010 | Acer Aspire™ T180 PC Desktop
Magicjack does not recognize my phone
"However the phone option is not available..." Are you sure? you can switch to headset or by phone anytime you want. Switching to either one of these devices you need to right click on your magicJack phone number in the software(located at the top left portion) and click on "switch to phone/telephone".
Feb 08, 2009 | GTech HARD DRIVE, G SPEED eS,4TB W/PCIe...
Using computer to record voicemails
If this hasn't been solved, I am a certified Vodavi Tech. Give me a ring
Sep 17, 2008 | Vodavi 30-Button XTS Telephone
SPEAKERS NOT WORKING
hello
Try to check if your sound card driver is installed
AYADI
Apr 05, 2008 | Acer Aspire™ T180 PC Desktop
We have recently purchased a brother mfc-240c, and as far as i no i have installed it correectly yet when trying to use the fax it dails a dead tone and continues to redail but doesnt send, and we...
make sure you have a dial tone by plugging a different phone into the jack. then make sure you have it plugged into the jack on the fax that says line.
Mar 08, 2008 | Uniden Cordless Phone
No Dial Tone on phones or modem
possible its in your telephone wires, try check it with a liscensed technician of your telephone company.Maybe the wire threads are broken or even worn out.
Jan 30, 2008 | HP Compaq Presario Media Center SR1750NX...
Audio/Video questions
as to your audio the only way for you to get 5.1 is to get a sound card that supports it i think the computer you have only supports 2.1. you can find a cheap sound card at places like tigerdirect or newegg, also try ebay. same goes for your video you need to find one with a tv output.
Dec 20, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
