Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
Sanyo 20" TV LCD ETV
I turned the TV off, went to sleep, tried to turn it back on, but nothing happened. The set simply just would not turn on. I proceeded to open up the tv, and just look inside to verify the components were still intact, and check for debris or charring from bad components. The set was clean, and had no physical defects to the naked eye, and all components appeared to be intact. The only thing I did not check was the power cord. The is no light indicator on the power supply, so I am not sure if it is working. I do not have a meter present to actually verify the voltage coming out of the the supply, and do not have another supply to swap with. Any help you can give would be appreciated.
Thank You!!
    Problem Solver:
  • 25 Answers
Just check the AC wall outlet by using volt meter tester,if the outlet ok check blown fuse if ok proceed to power supply section.
Posted on Sep 08, 2008
My TV won't turn on. I have a 42" Sanyo LCD TV. We
You have a back light issue. Sometimes it's cheaper to get another one. Tcon board failure most likely. If you can find a rv repair or electronics repair they might do the work but as you got 5 years from it. Most TV sets fail in less time than that.
Jul 20, 2017 | Televison & Video
Sanyo DP 42849 42'' lcd tv no audio no video
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 03, 2017 | Sanyo DP42849 42 in. HDTV
My 26' sanyo vizon wont turn on and i dont know why.
I have the same tv. Was watching last night when it turned itself off. When I tried turning it back on the switch just made a click noise and nothing happened. After a couple more tries, it didn't even do that.
Jan 26, 2010 | Sanyo DP26746 26 in. LCD Television
Lost house power. Sanyo clt2054 20 turned off now won't turn back on
Check the power supply for fuse, loose connections, etc. What happen when the power went out and came back on, you will usually get higher voltage when it comes back on, you will notice that the light bulb gets very bright when the power comes back on.
Nov 24, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
TV won't come on
its the problem of small electrical components on the main board gone faulty due to over use it got over heated and they r blowned out.so needs to be replaced.
Nov 25, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
My Sanyo TV DS20930 wont turn ON at all
try unplugging for the power source for 60 seconds hold in the power for 10 seconds then plug the power cord while you are hold int power button in then release the power button... now try it (turn it on)
Apr 17, 2008 | Sanyo DS20930 20" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sleep timer on
did you try to unplug and start all over again ? set time and day etc...
Oct 31, 2007 | Sanyo DS20930 20" TV
TV Won't work
If you were watching the set and it went off bt itself is not likely is in any sleep mode,you have already tried unplugin the unit that did not work,The set needs service to diagnose what happened,I am sure is nothing you could have prevented,it just failed by itself.Is lees expensive if take the set to a servicer for an estimate.
Oct 02, 2006 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
260 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
