Question about Kenmore Elite 45986 Front Load Washer
How do you open the front cover for Kenmore front loader 110.42926200
I cannot open the front cover for the Kenmore Elite front loader 110.42926200 to check my pump. Can anyone help ?
    Novelist:
    Champion:
  • 261 Answers
Sure thing, under the door is a kick panel, held on by three hex screws,standard uses 1/4 inch and torx uses a 9/32 socket. A slight down tug will loosen the panel and behind that you will see the pump at right front. Just to the left is a round soda can shaped housing with a large turn screw lid attached to the pump. Grab a bucket and some towels, unscrew the lid like a jar of peanut butter slowly to let the water into the bucket. This may require two trips and some getting wert. The trap is attached and easy to clean. Next reach behind a gently shake the black boot joining the tub to the pump for coins and lint. The last item is getting a bright light and inspecting the pump through the small hole right side that can be seen once the trap is removed. Check for debris then put a finger in the hole and check the impeller for disconnection from debris/
Posted on Sep 13, 2008
How do you open the top on a kenmore elite washer to access the tube.
on a top loader the controls are flipped up then the cabinet gets removedthemobilian_2256.jpg
front loader yall remove screws from the back and lift the top off
Apr 30, 2011 | Kenmore Washing Machines
Kenmore elliet washing machine, front loader
To open the door manually:
UNPLUG the machine...
Remove the toekick panel (way down at the bottom).
Feeling along the inside of the front panel. You should be able to find a tab shaped like a teardrop attached to the door latch unit.
Pull the tab down just a little bit ... gently ... until the door opens (or you hear the latch click - then try to open the door).
Is the machine displaying a code?
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
How do you open a locked kenmore elite front loader door after the power/motor is broken
You can use the manual release to open the door. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite front loader leaks
well you can remove teh boootm acess panel by removingthe 3 screws that run along the bootm of the unit . afete rthat you can set a cycle to wash ans see where the leak is coming from
Jan 28, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
311 people viewed this question
Sal De
fordexpert
Robert Rankin
